avdwilk
(Alex )
May 11, 2021, 12:17pm
1
Hello, i am automating my Magnum Heating floor heating with my magnum w-controller. So I bought a Elfin-EW11 and configured modbus tcp. if i use modbus poll i can see it is working. current temperature is in register 1101 and target temperature is in register 1107 (needs to be devided by 100). see picture, the temperature in the living is 24.6 degrees and 18.5 is set.
when i configure homeassistant in the yaml configuration:
modbus:
type: tcp
host: x.x.x.x
port: 502
climates:
slave: 1
data_type: int
data_count: 1
scale: 0.01
offset: 0
precision: 1
max_temp: 30
min_temp: 15
temp_step: 0.5
temperature_unit: C
target_temp_register: 1107
current_temp_register: 1101
current_temp_register_type: input
and i configure a thermostat in the lovelace only the current temperature is given. it looks like the target temperature is not working.
i think i am missing something.
Chef-70
(Jef Horians)
October 2, 2023, 5:53pm
2
Hi Alex,
Did you ever get this working right?
I also own a W-controller from Magnum and want to be able to take control more.
Thank you,
Jef
avdwilk
(Alex )
October 2, 2023, 6:17pm
3
Yes I did, I called magnum and asked for all the registers of the modbus.
After that I made a sensor of every thermostat (2x cooling and heating).
After that I used a conditional card to switch between cooling and heating, I can also ajust every thermostat now.
Hi Alex, I have the same Magnum controller. I purchased the Elfin convertor as you mentioned. Can you share the steps you’ve taken to get this setup working?
Thanks,
Stijn
Hi Alex, could you please help me out setting up the correct configuration? I have the exact same setup and would really appreciate the correct config.
Thanks in advance!
Stijn
avdwilk
(Alex )
November 6, 2024, 10:40am
6
modbus:
type: tcp
host: x.x.x.x
port: 502
sensors:
slave: 1
address: 1914
data_type: int16
input_type: input
climates:
slave: 1
data_type: int16
scale: 0.01
offset: 0
precision: 1
max_temp: 30
min_temp: 15
temp_step: 0.5
target_temp_register: 1901
address: 1901
input_type: input
slave: 1
data_type: int16
scale: 0.01
offset: 0
precision: 1
max_temp: 30
min_temp: 15
temp_step: 0.5
target_temp_register: 1902
address: 1901
input_type: input
type: conditional
conditions:
entity: sensor.thermostat_state_slaapkamer_xxxx
state: “2”
card:
entities:
entity: climate.slaapkamer_xxxx_manal
type: custom:simple-thermostat
step_size: 0.5
hide:
state: true
control: false
header: false
title: Slaapkamer_xxxx
type: entities
type: conditional
conditions:
state: “7”
card:
entities:
entity: climate.slaapkamer_xxxx_cool
step_size: 0.5
hide:
state: true
control: false
header: false
type: entities
Chef-70
(Jef Horians)
December 21, 2024, 8:56am
7
Chef-70
(Jef Horians)
December 29, 2024, 9:34am
8
avdwilk:
Elfin-EW11
@avdwilk
Ik krijg het niet aan de gang. Gezien het feit dat jij het werkend hebt, gaat om dit ding?
Elfin-EW11 – Koop Elfin-EW11 met gratis verzending op AliExpress version
avdwilk
(Alex )
December 29, 2024, 11:54am
9
Volgens mij is dat een wifi ding, ik heb een ethernet to rs485 module de ee11 ipv de ew11, maar in principe zou dat niet uit mogen maken…
Krijg je wel de webpagina van de ew11 geopend op de computer?
Chef-70
(Jef Horians)
December 29, 2024, 12:07pm
10
Het is geen EW11. Ik had eerst even moeten kijken wat jij gebruikte.
Het is dit ding en ik kan de website benaderen. Om Modbus gezet maar het lukt niet echt. TTL UART to Ethernet Mini Module, Castellated Holes With Immersion Gold Design, Highly Integrated Packaging | UART TO ETH (B)
avdwilk
(Alex )
December 29, 2024, 9:04pm
11
Als je Modbus poll installeert zie je dan geen data
Wellicht het a en b kanaal omdraaien anders
Chef-70
(Jef Horians)
December 30, 2024, 8:22am
12
Nee, verschillende van die programma’s geprobeerd.
Ben er ondertussen ver ingedoken en als test diagslave op een Raspberry Pi op Ubuntu geïnstalleerd en dat werkt allemaal wel.
Ondertussen heb ik de Elfin-EW11A besteld. Ben benieuwd.
