Good day, My modbus config has suddenly broken,
And I cant seem to understand the error.
Invalid config for 'modbus' at modbus.yaml, line 10: not a valid value for dictionary value 'modbus->0->type', got 'tcp', please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 11: 'host' is an invalid option for 'modbus', check: modbus->0->host, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 8: required key 'baudrate' not provided, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 8: required key 'bytesize' not provided, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 8: required key 'method' not provided, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 8: required key 'parity' not provided, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 8: required key 'stopbits' not provided, please check the docs at https://www.home-assistant.io/integrations/modbus Invalid config for 'modbus' at modbus.yaml, line 9: 'retries' is an invalid option for 'modbus', check: modbus->0->retries, please check the docs at https://www.home-assistant.io/integrations/modbus
here is my config:
# system :
- name: victron
type: tcp
host: 192.168.1.190
port: 502
sensors:
# L1 Grid power
- name: "Multiplus Grid power"
unit_of_measurement: "W"
slave: 100
address: 820
data_type: int16
scan_interval: 5
device_class: power
I see its talking about parity and stop bits etc, which is all related to serial?
I have specifically selected:tcp and my configuration looks like their example?
what am I missing here?
I don’t have reties anywhere?
