Modbus configuration: duplicate address, entity not loaded
Hi guys!
I have this modbus configuration for 5 shutters, a single address (570) and a single slave (66).
modbus:
  - name: hub1
    type: serial
    method: rtu
    port: /dev/ttyUSB0
    baudrate: 9600
    stopbits: 1
    bytesize: 8
    parity: E
    sensors:
      - name: read_status_shutter
        slave: 66
        address: 606
        scale: 1
        data_type: int16
        scan_interval: 5
    switches:
      - name: shutter_stop
        slave: 66
        address: 570
        command_on: 40
        verify:
            input_type: holding
            address: 606
            state_off: 0
    covers:
      - name: "shutter 0"
        device_class: shutter
        state_open: 51
        state_opening: 1
        state_closed: 41
        state_closing: 64
        status_register: 606
        slave: 66
        address: 570
      - name: "shutter 1"
        state_open: 52
        state_opening: 2
        state_closed: 42
        state_closing: 66
        slave: 66
        address: 570
      - name: "shutter 2"
        state_open: 53
        state_opening: 4
        state_closed: 43
        state_closing: 68
        slave: 66
        address: 570
      - name: "shutter 3"
        state_open: 54
        state_opening: 8
        state_closed: 44
        state_closing: 72
        slave: 66
        address: 570
      - name: "shutter 4"
        state_open: 55
        state_opening: 16
        state_closed: 45
        state_closing: 80
        slave: 66
        address: 570
When I restart the HA server I have this problem
Logger: homeassistant.components.modbus.validators
Source: components/modbus/validators.py:202
Integration: Modbus (documentation, issues)
First occurred: 21:17:42 (4 occurrences)
Last logged: 21:17:42
  • Modbus cover/shutter 1 address 570_66 is duplicate, second entry not loaded!
  • Modbus cover/shutter 2 address 570_66 is duplicate, second entry not loaded!
  • Modbus cover/shutter 3 address 570_66 is duplicate, second entry not loaded!
  • Modbus cover/shutter 4 address 570_66 is duplicate, second entry not loaded!
So, I don’t have the 5 entities of my shutters, but only the first one is created.
Anyone have any advice for me?
Thanks!
You have the same status register listed for each shutter. 606.
I believe it is saying that using the same status register for multiple covers is invalid.
Looks like a bad error message. If that’s the root cause create an issue so a better error is reported.
I need the status_register with 606 to know the status of all my shutters and I have no problems if it always remains the same.
I did some tests where I changed my address 570 with random values and the duplicate address problem disappears.
But having 5 different addresses is not a solution to my problem. I only have address 570 to write to.
Open a home assistant issue for modbus integration and see if the devs can help you.
