mprimog
(Marcos)
April 3, 2020, 5:06pm
1
I am testing deepply Modbus integration.
TCP integration works well.
I am now with “serial” and i am getting an error in the configuration:
File “/usr/src/homeassistant/homeassistant/setup.py”, line 170, in _async_setup_component
hass, processed_config
File “/config/custom_components/modbus/init .py”, line 102, in async_setup
hub_collect[client_config[CONF_NAME]] = ModbusHub(client_config, hass.loop)
File “/config/custom_components/modbus/init .py”, line 174, in init
self._config_delay = client_config[CONF_DELAY]
KeyError: ‘delay’
Any clue?
This is my configuration
modbus:
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
Thanks a lot.
Marcos.
jocnnor
(Jim O'Connor)
April 3, 2020, 5:41pm
2
Looks like it was updated 5 days ago…but the documentation hasn’t been updated.
It was added with this change
committed 05:39PM - 29 Mar 20 UTC
* modbus: bumb pymodbus version to 2.3.0
pymodbus version 1.5.2 did not support asyncio, and in general
the async handling...
Delay was added to ethernet config, but not to serial. But, the ModBusHub expects it.
So it’s a bug.
Go ahead and open an issue for it!
mprimog
(Marcos)
April 4, 2020, 12:19pm
3
Thanks for the reply @jocnnor .
I tried to modify the init file adding delay to SERIAL validation but later i get other error in the pymodbus related to asyncio so I guess I am using 1.5.2 pymodbus. In the meantime I will upgrade pymodbus and continue testing.
I am new in HA. How should I open an issue?
Thanks.
