Note that this was done for a NIBE S1155 PC, but would expect the majority to work for other heatpumps from the S series as well.
After combining information from the modbus documentation from NIBE themselves, the exported CSV from the heatpump and a lot of trail and error (with the assistance of myuplink), I would like to share the current yaml I have for at least the majority of sensors as included in the ‘info’ menu.
More than willing to receive any feedback and or comments, particularly as I would not consider myself experienced with this kind of stuff yet, hence any best practices are welcome.
Added comments where possible, including some deviations (mainly data type) between the modbus reference and what I ended up using, in the comments you’ll find what is included in the most recent version of the reference document.
- name: "NIBE S1155"
type: tcp
host: 192.168.2.11
port: 502
sensors:
# 3.1.2 Overview
- name: "Operating Prioritisation"
unique_id: "operating_prioritisation"
data_type: int16 # int8
# 10: Off, 20: Hot Water, 30: Heat, 40: Pool, 50: Cooling
address: 1028
input_type: input # R/W
scale: 1
precision: 0
state_class: measurement
slave: 1
- name: "Power Usage"
unique_id: "power_usage"
unit_of_measurement: "W"
data_type: int16
device_class: power
address: 2166
input_type: input
scale: 1
precision: 0
slave: 1
# 3.1.3 Heating
- name: "Degree Minutes (Heating)"
unique_id: "degree_minutes_heating"
unit_of_measurement: "DM"
data_type: int16
address: 18
input_type: holding # R/W
scale: 0.1
precision: 1
slave: 1
- name: "Room Temperature" # BT50
unique_id: "room_temperature_bt50"
unit_of_measurement: "°C"
data_type: int16
device_class: temperature
address: 116 # 116 for RMU S40, 26 for BT50
scale: 0.1
precision: 1
slave: 1
- name: "Calculated Supply (Heating)"
unique_id: "calculated_supply_heating"
data_type: int16
address: 1017
scale: 0.1
precision: 1
slave: 1
- name: "Supply Line Temperature" # BT2
unique_id: "supply_line_temperature_bt2"
data_type: int16
address: 5
scale: 0.1
precision: 1
slave: 1
- name: "Return Line Temperature" # BT3
unique_id: "return_line_temperature_bt3"
data_type: int16
address: 7
scale: 0.1
precision: 1
slave: 1
- name: "Outdoor Temperature" # BT1
unique_id: "outdoor_temperature_bt1"
data_type: int16
address: 1
scale: 0.1
precision: 1
slave: 1
- name: "Average Outdoor Temperature"
unique_id: "average_outdoor_temperature"
data_type: int16
address: 37
scale: 0.1
precision: 1
slave: 1
- name: "Condenser Supply" # BT12
unique_id: "condenser_supply_bt12"
data_type: int16
address: 12
scale: 0.1
precision: 1
slave: 1
- name: "Brine In" # BT10
unique_id: "brine_in_bt10"
data_type: int16
address: 10
scale: 0.1
precision: 1
slave: 1
- name: "Brine Out" # BT11
unique_id: "brine_out_bt11"
data_type: int16
address: 11
scale: 0.1
precision: 1
slave: 1
- name: "Underfloor Drying Function"
unique_id: "underfloor_drying_function"
data_type: int16
address: 120
input_type: holding
scale: 1
precision: 0
slave: 1
# 3.1.4 Hot Water
- name: "Hot Water Demand" # aka "Comfort Mode"
unique_id: "hot_water_demand"
# 0: Small, 1: Medium, 2: Large, 3: Smart Control
address: 56
scale: 1
precision: 0
slave: 1
- name: "Hot Water Charging" # BT6
unique_id: "hot_water_charging_bt6"
data_type: int16
address: 9
scale: 0.1
precision: 1
slave: 1
- name: "Hot Water Top" # BT7
unique_id: "hot_water_top_bt7"
data_type: int16
address: 8
scale: 0.1
precision: 1
slave: 1
# 3.1.5 Cooling
- name: "Calculated Supply (Cooling)"
unique_id: "calculated_supply_cooling"
data_type: int16
address: 1567
scale: 0.1
precision: 1
slave: 1
# 3.1.7 Compressor
- name: "Compressor Frequency"
unique_id: "compressor_frequency"
unit_of_measurement: "Hz"
data_type: int16 # uint16
device_class: frequency
address: 1046
scale: 0.1
precision: 0 # could be set to 1
slave: 1
- name: "Requested Compressor Frequency"
unique_id: "requested_compressor_frequency"
data_type: int16
address: 140
scale: 1
precision: 0
slave: 1
- name: "Minimum Compressor Frequency"
unique_id: "minimum_compressor_frequency"
data_type: int16
address: 1041
scale: 1
precision: 0
slave: 1
- name: "Compressor Status"
unique_id: "compressor_status"
data_type: int16 # uint8
# 0: Off, 1: On (Operate)
address: 1100
scale: 1
precision: 0
slave: 1
- name: "Discharge" # BT14
unique_id: "discharge_bt14"
data_type: int16
address: 13
scale: 0.1
precision: 1
slave: 1
- name: "Liquid Line" # BT15
unique_id: "liquid_line_bt15"
data_type: int16
address: 14
scale: 0.1
precision: 1
slave: 1
- name: "Suction Gas" # BT17
unique_id: "suction_gas_bt17"
data_type: int16
address: 16
scale: 0.1
precision: 1
slave: 1
- name: "Inverter Temperature"
unique_id: "inverter_temperature"
data_type: int16
address: 1047
input_type: input
scale: 0.1
precision: 1
slave: 1
# 3.1.9 Additional Heating
- name: "Status Additional Heating"
unique_id: "status_additional_heating"
data_type: int16
address: 1029
input_type: input
scale: 1
precision: 0
slave: 1
- name: "Power Usage Additional Heating"
unique_id: "power_usage_additional_heating"
unit_of_measurement: "kW"
data_type: int16
device_class: power
address: 1027
scale: 0.01
precision: 1
slave: 1
- name: "Maximum Power Usage Additional Heating"
unique_id: "maximum_power_usage_additional_heating"
data_type: int16
device_class: power
address: 102
scale: 0.01
precision: 1
slave: 1
- name: "Fuse Size"
unique_id: "fuze_size"
unit_of_measurement: "A"
data_type: int16
device_class: current
address: 103
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Current Phase 1" # BE1
unique_id: "current_be1"
data_type: uint32
address: 50
scale: 0.1
precision: 1
slave: 1
- name: "Current Phase 2" # BE2
unique_id: "current_be2"
data_type: uint32
address: 48
scale: 0.1
precision: 1
slave: 1
- name: "Current Phase 3" # BE3
unique_id: "current_be3"
data_type: uint32
address: 46
scale: 0.1
precision: 1
slave: 1
# 3.1.10 Circulation Pumps
- name: "Operating Mode Heating Pump"
unique_id: "operating_mode_heating_pump"
data_type: int16
# 0: Auto, 1: Manual
address: 853
scale: 1
precision: 0
slave: 1
- name: "Heating Pump Speed" # GP1
unique_id: "heating_pump_speed"
unit_of_measurement: "%"
data_type: int16
device_class: power_factor
address: 1102
scale: 1
precision: 0.1
slave: 1
- name: "Heating Pump Speed (Manual)"
unique_id: "heating_pump_speed_manual"
data_type: int16
address: 218
scale: 1
precision: 0.1
slave: 1
- name: "Brine Pump Speed" # GP2
unique_id: "brine_pump_speed"
data_type: int16
address: 1104
scale: 1
precision: 0.1
slave: 1
- name: "Brine Pump Speed (Manual)"
unique_id: "brine_pump_speed_manual"
data_type: int16
address: 222
scale: 1
precision: 0.1
slave: 1
# 3.1.12 Statistics
- name: "Number Of Starts (Compressor)"
unique_id: "number_of_starts_compressor"
data_type: int16
address: 1534
input_type: input
scale: 1
precision: 0
state_class: total_increasing
slave: 1
- name: "Operating Time (Total)"
unique_id: "operating_time_total"
data_type: int16
address: 1536
input_type: input
scale: 1
precision: 0
slave: 1
- name: "Operating Time (Hot Water)"
unique_id: "operating_time_hot_water"
data_type: int16
address: 1538
input_type: input
scale: 1
precision: 0
slave: 1
- name: "Flow Hot Water (Compressor)"
unique_id: "flow_hot_water_compressor"
unit_of_measurement: "kWh"
data_type: int16
device_class: energy
address: 1583
input_type: input
scale: 0.1
precision: 1
slave: 1
- name: "Flow Hot Water (Total)"
unique_id: "flow_hot_water_total"
data_type: int16
address: 1575
input_type: input
scale: 0.1
precision: 1
slave: 1
- name: "Flow Heating (Compressor)"
unique_id: "flow_heating_compressor"
data_type: int16 # No idea what this should be
address: 1585
input_type: input
scale: 0.1
precision: 1
slave: 1
- name: "Flow Heating (Total)"
unique_id: "flow_heating_total"
address: 1577
input_type: input
scale: 0.1
precision: 1
slave: 1
# To bo categorised
- name: "Active Alarm"
unique_id: "active_alarm"
address: 2195
input_type: input
scale: 1
precision: 0
slave: 1
- name: "Alarm Number"
unique_id: "alarm_number"
address: 1975
input_type: input
scale: 1
precision: 0
slave: 1
- name: "Start Compressor"
unique_id: "start_compressor"
data_type: int16
address: 159
input_type: holding
scale: 1
precision: 1
slave: 1
- name: "Start Additional Heat"
unique_id: "start_additional_heat"
data_type: int16
address: 97
input_type: holding
scale: 1
precision: 1
slave: 1
- name: "Degree Minutes Cooling"
unique_id: "degree_minutes_cooling"
data_type: int16
address: 20
input_type: holding
scale: 1
precision: 1
slave: 1
- name: "Reset Alarm"
unique_id: "reset_alarm"
address: 22
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Heating Curve" # 1.30.1
unique_id: "heating_curve"
address: 26
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Heating Curve Offset" # 1.30.1
unique_id: "heating_curve_offset"
address: 30
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Supply Temperature Min" # 1.30.4
unique_id: "supply_temperature_min"
address: 34
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Supply Temperature Max" # 1.30.6
unique_id: "supply_temperature_max"
address: 38
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Own Curve" # 1.30.7
unique_id: "own_curve"
address: 39 # 39-45
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Flow Sensor (BF1)"
unique_id: "flow_sensor_bf1"
unit_of_measurement: "l/min"
data_type: int16
address: 40
input_type: input
scale: 0.1
precision: 1
slave: 1
- name: "Start Temperature Hot Water"
unique_id: "start_temperature_hot_water"
address: 59
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Stop Temperature Hot Water"
unique_id: "stop_temperature_hot_water"
address: 63
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Period Time Heating" # unclear unit, hours per day?
unique_id: "period_time_heating"
unit_of_measurement: "h"
address: 92
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Period Time Hot Water" # unclear unit, hours per day?
unique_id: "period_time_hot_water"
address: 93
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Period Time Cooling" # unclear unit, hours per day?
unique_id: "period_time_cooling"
address: 94
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Start Temperature Cooling"
unique_id: "start_temperature_cooling"
address: 183
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Stop Temperature Heating"
unique_id: "stop_temperature_heating"
address: 184
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Stop Temperature Additional Heating"
unique_id: "stop_temperature_additional_heating"
address: 185
input_type: holding
scale: 0.1
precision: 1
slave: 1
- name: "Lower Room Temperature Alarm"
unique_id: "lower_room_temperature_alarm"
address: 196
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Lower Hot Water Temperature Alarm"
unique_id: "lower_hot_water_temperature_alarm"
address: 197
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Operating Mode" # 4.1
# 0: auto, 1: manual, 2: additional heating only
unique_id: "operating_mode"
address: 237
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Allow Additional Heating (Manual)" # 4.1
unique_id: "allow_additional_heating_manual"
address: 180
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Allow Heating (Manual)" # 4.1
unique_id: "allow_heating_manual"
address: 181
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Allow Cooling (Manual)" # 4.1
unique_id: "allow_cooling_manual"
address: 182
input_type: holding
scale: 1
precision: 0
slave: 1
- name: "Total Run Time Additional Heat" # Value does not align with UpLink?
unique_id: "total_run_time_additional_heat"
data_type: int32
address: 1025
input_type: input
scale: 0.1
precision: 1
slave: 1
- name: "Compressor Statistics (EP14)"
unique_id: "compressor_statistics_ep14"
data_type: int32
address: 1087
input_type: input
scale: 1
precision: 0
slave: 1
