I have a Wago PLC 750 using modbus over ethernet. I am struggling to set up a simple configuration file to activate some coils.
To make it simple, how do I create a switch to turn on and off the coil at QX0.3 in my output module (DO)? I used the following code in configuration.yaml and the switch is showing up but is greyed out (it says something about not having a unique ID).
are you using codesys 3.5 like me?
I’ve been struggling with addressing it for days. The only thing I managed is a coil with the following settings:
modbus:
Does this help?
Maybe we can help each other because i think most of this HA Modbus doesn’t work or is completely out of IEC norm or a product of coincidence.Or i’m just don’t know what i’m doing…
Hello, Have any of you manage to communicate the Wago plc to Hass? I am trying the same thing and having difficulty in mapping the modbus registry to send values to HASS.
thank you!
