MODBUS data from SMA Inverter
2020-11-27_17-41-19
The UnitID on my Sunny Explorer = … ? 16… ?
I’m trying to get this working with node red but keep getting errors.
Look again on my screenshot. The UnitID is in the Modbus Section. You are looking outside the Modbus Section
Thanks Chris_ka. But i dont see something else that looks like it. For know i use 3. And its working fine :slight_smile:
Hi.
I’m also using 0.118.5 (homeasistant installed on raspberry pi4) and modbus to read sma sunny boy 3.6 tl inverter.
Till 0.118 every thing worked fine, now I can’t see the inverter parameters.
I tried via shifting registers with +1 and also via -1 but nothing changed.
Do you have any hints?
On config.yaml
modbus:
type: tcp
host: 192.168.1.51
port: 502
(here I also tried to put timeout: 10 without changes)
On sensor.yaml
  • platform: modbus
    scan_interval: 10
    registers:
    • name: smadevtype
      hub: sma
      slave: 3
      register: 30052
      count: 2
      data_type: uint
    • name: smagridrelay
      hub: sma
      slave: 3
      register: 30216
      count: 2
      data_type: uint
    • name: smatotal
      hub: sma
      unit_of_measurement: kWh
      slave: 3
      register: 30530
      count: 2
      data_type: uint
      scale: 1
      precision: 2
    • name: smatoday
      hub: sma
      slave: 3
      register: 30536
      count: 2
      data_type: uint
      scale: 1
      precision: 2
    • name: smapwr
      hub: sma
      unit_of_measurement: W
      slave: 3
      register: 30774
      count: 2
      data_type: int
      scale: 1
      precision: 2
    • name: smapwrL1
      hub: sma
      slave: 3
      register: 30776
      count: 2
      data_type: uint
      scale: 0.001
      precision: 2
    • name: smavoltL1
      hub: sma
      unit_of_measurement: V
      slave: 3
      register: 30782
      count: 2
      data_type: uint
      scale: 0.01
      precision: 1
    • name: smanetHZ
      hub: sma
      unit_of_measurement: Hz
      slave: 3
      register: 30802
      count: 2
      data_type: uint
      scale: 0.01
      precision: 2
    • name: smacurl1
      hub: sma
      unit_of_measurement: A
      slave: 3
      register: 30976
      count: 2
      data_type: int
      scale: 0.001
      precision: 3
  • platform: template
    sensors:
    sma_power_l1:
    value_template: “{% if states(‘sensor.smapwrl1’)|float > 10000 %}0{% else %}{{ states(‘sensor.smapwrl1’) | float | round(2)}}{% endif %}”
    friendly_name: “sma power L1”
    unit_of_measurement: ‘kW’
    icon_template: mdi:solar-power
    sma_stroom_l1:
    value_template: “{% if states(‘sensor.smacurl1’)|float > 100 %}0{% else %}{{ states(‘sensor.smacurl1’) | float | round(2)}}{% endif %}”
    friendly_name: “sma stroom L1”
    unit_of_measurement: ‘A’
    sma_spanning_l1:
    value_template: “{% if states(‘sensor.smavoltl1’)|float > 1000 %}220{% else %}{{ states(‘sensor.smavoltl1’) | float | round(2)}}{% endif %}”
    friendly_name: “sma spanning L1”
    unit_of_measurement: ‘V’
    sma_netfrequentie:
    value_template: “{% if states(‘sensor.smanethz’)|float > 1000 %}50{% else %}{{ states(‘sensor.smanethz’) | float | round(2)}}{% endif %}”
    friendly_name: “sma Netfrequentie”
    unit_of_measurement: ‘Hz’
    sma_power:
    value_template: “{% if states(‘sensor.smapwr’)|float < 0 %}0{% else %}{{ states(‘sensor.smapwr’) | float | round(2)}}{% endif %}”
    friendly_name: “sma Power”
    sma_total:
    value_template: “{% if states(‘sensor.smatotal’)|float < 0 %}0{% else %}{{ states(‘sensor.smatotal’) | float | round(3)}}{% endif %}”
    friendly_name: “sma Total”
    unit_of_measurement: ‘kWh’
    sma_today:
    value_template: “{% if states(‘sensor.smatoday’)|float > 1000 %}0{% else %}{{ states(‘sensor.smatoday’) | float | round(2)}}{% endif %}”
    friendly_name: “sma Today”
    sma_device_type:
    value_template: “{% if states(‘sensor.smadevtype’)|float == 9347 %}Tripower 8.0{% else %}?{% endif %}”
    friendly_name: “sma device type”
    sma_grid_relay:
    value_template: “{% if states(‘sensor.smagridrelay’)|float == 51 %}closed{% elif states(‘sensor.smagridrelay’)|float == 311 %}open{% elif states(‘sensor.smagridrelay’)|float == 9165 %}Disconnesso{% else %}?{% endif %}”
    friendly_name: “sma grid relay”
Into Logs I also still have that alarm
Logger: pymodbus.client.sync
Source: /usr/local/lib/python3.8/site-packages/pymodbus/client/sync.py:214
First occurred: 7:47:07 (198 occurrences)
Last logged: 7:58:04
  • Connection to (192.168.1.51, 502) failed: timed out
  • Connection to (192.168.1.22, 502) failed: [Errno 104] Connection reset by peer
Can somebody helping me?
When my SMA is off (by night) i got weird values on my Actual power and the Power Fases.
Attachment you see my printscreen and piece of the code examples.
Sensors
  - platform: modbus
    scan_interval: 10
    registers:
    - name: SMA_Power_AC
      slave: 3
      register: 30775
      count: 2
      data_type: int
    - name: Grid Voltage Fase 1
      slave: 3
      register: 30783
      count: 2
      scale: 0.01
      precision: 2
      data_type: uint
PV Power template
      modbus_sma_pv_power:
        entity_id: sensor.sma_power_ac
        friendly_name: 'Power Output'
        value_template: >-
            {% if states('sensor.sma_power_ac')|float < 0 or states('sensor.sma_power_ac')|float > 6000 %}
              0
            {% else %}
              {{ states('sensor.sma_power_ac') }}
            {% endif %}
        unit_of_measurement: "W"
        icon_template: mdi:flash-circle
Fase 1 Template
      modbus_grid_voltage_Fase 1:
        entity_id: sensor.grid_voltage_Fase_1
        friendly_name: 'Grid Voltage l1'
        value_template: >-
            {% if states('sensor.grid_voltage_Fase_1')|float < 180 or states('sensor.grid_voltage_Fase_1')|float > 300 %}
              Not Measured
            {% else %}
              {{ states('sensor.grid_voltage_Fase_1') }}
            {% endif %}
        unit_of_measurement: "V"
Anyone having issue with Modbus integration not showing values? For some reason I do not see any values for the last few days. When I login to portal I see data still.
Hi!
did u find a solution?
I have sunntboy 2.5 with modbus integration.
During night my HA frontend brakes because i have tons of errors generated from unreachable sunnyboy.
2021-06-02 23:09:37 ERROR (SyncWorker_58) [homeassistant.components.modbus.modbus] Pymodbus: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
2021-06-02 23:09:40 ERROR (SyncWorker_45) [pymodbus.client.sync] Connection to (192.168.1.16, 502) failed: timed out
is it true that the sunnyboy doesn’t work during night and goes into night mode?
I dunno how to solve this issue, i have an error every few seconds.
Thank you for anyone can help
I have the same issue.
I get verry sparce data over the modbus from my sma converter.
Connection broke a fiew days avo.
Logger: homeassistant.components.modbus.sensor
Source: components/modbus/sensor.py:110
Integration: Modbus (documentation, issues)
First occurred: 11 juni 2021 15:09:05 (1 occurrences)
Last logged: 11 juni 2021 15:09:05
Sensor configuration is deprecated, will be removed in a future release
Any ideas?.
Hi chris_ka,
I have tried your code for the template sensor, as my inverter shows -2,147,483,648W during night time which screws up my Grafana chart. I had no luck, it does not show up under Sensors in the Dashboard :frowning: What am I doing wrong?
  power_sma_filtered:
    friendly_name_template: "Erzeugung aktuell"
    value_template: >-
      {% if (states('sensor.sma_power_ac')|int >= 10000 or states('sensor.sma_power_ac')|int < 0) %}
        0
Hi Stefan,
to use a template sensor you need to define it as such by using
    section instead of
  • platform: modbus
Hi Chris,
thank you, stupid mistake on my side - it works now :slight_smile:
HI
Untill now I was using Chris’s node red setup and MBolt modbus code. With current version of home assistant modbus changed and I cant see anymore my solar power. I can see power consumption from home manager but nothing from invertor. Would anyone be able to help what needs to be chnaged in the modbus code (yaml) from MBolt to get it working again? I have tried the home assistant official solar integration but getting connection error so that doesnt work.
Hello.
In my case modbus platform configured for sma reading is working well… Exept for some modbus communication dopout. Tipically one, maximum two times per day I need to restart Ha because every sensor from modbus sma gone to value 0 (zero)
After HA restart, everything is ok.
This happened only with new integration. Before Core update everything was ok.
Are there any settings to put, to avoid this behaviour.?
Below mine configuration
On config.yaml
modbus:
  - name: sma
    type: tcp
    host: 192.168.1.51
    port: 502
    sensors:
    # - platform: modbus
      # registers:
      - name: SMApwrL1
        # hub: sma
        slave: 3
        address: 30777
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMApwrL2
        # hub: sma
        slave: 3
        address: 30779
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMApwrL3
        # hub: sma
        slave: 3
        address: 30781
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAcurL1
        # hub: sma
        slave: 3
        address: 30977
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAcurL2
        # hub: sma
        slave: 3
        address: 30979
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAcurL3
        # hub: sma
        slave: 3
        address: 30981
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAvoltL1
        # hub: sma
        slave: 3
        address: 30783
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
      - name: SMAvoltL2
        # hub: sma
        slave: 3
        address: 30785
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
      - name: SMAvoltL3
        # hub: sma
        slave: 3
        address: 30787
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
      - name: SMAnetHZ
        # hub: sma
        slave: 3
        address: 30803
        count: 2
        data_type: uint
        scale: 0.01
        precision: 2
      - name: SMApwr
        # hub: sma
        slave: 3
        address: 30775
        count: 2
        data_type: int
        scale: 0.001
        precision: 2
      - name: SMAtotal
        # hub: sma
        slave: 3
        address: 30529
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAtoday
        # hub: sma
        slave: 3
        address: 30535
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
      - name: SMAdevtype
        # hub: sma
        slave: 3
        address: 30053
        count: 2
        data_type: int
      - name: SMAgridrelay
        # hub: sma
        slave: 3
        address: 30217
        count: 2
        data_type: int
On sma.yaml into packages
    sensors:
      sma_power_l1:
        value_template: "{% if states('sensor.smapwrl1')|float > 10000 %}0{% else %}{{ states('sensor.smapwrl1') | float | round(2)}}{% endif %}"
        friendly_name: "sma power L1"
        unit_of_measurement: 'kW'
      sma_power_l2:
        value_template: "{% if states('sensor.smapwrl2')|float > 10000 %}0{% else %}{{ states('sensor.smapwrl2') | float | round(2)}}{% endif %}"
        friendly_name: "sma power L2"
      sma_power_l3:
        value_template: "{% if states('sensor.smapwrl3')|float > 10000 %}0{% else %}{{ states('sensor.smapwrl3') | float | round(2)}}{% endif %}"
        friendly_name: "sma power L3"
      sma_corrente_l1:
        value_template: "{% if states('sensor.smacurl1')|float > 100 %}0{% else %}{{ states('sensor.smacurl1') | float | round(2)}}{% endif %}"
        friendly_name: "sma ampere L1"
        unit_of_measurement: 'A'
      sma_corrente_l2:
        value_template: "{% if states('sensor.smacurl2')|float > 100 %}0{% else %}{{ states('sensor.smacurl2') | float | round(2)}}{% endif %}"
        friendly_name: "sma ampere L2"
      sma_corrente_l3:
        value_template: "{% if states('sensor.smacurl3')|float > 100 %}0{% else %}{{ states('sensor.smacurl3') | float | round(2)}}{% endif %}"
        friendly_name: "sma ampere L3"
      sma_tensione_l1:
        value_template: "{% if states('sensor.smavoltl1')|float > 1000 %}230{% else %}{{ states('sensor.smavoltl1') | float | round(2)}}{% endif %}"
        friendly_name: "sma volt L1"
        unit_of_measurement: 'V'
      sma_tensione_l2:
        value_template: "{% if states('sensor.smavoltl2')|float > 1000 %}230{% else %}{{ states('sensor.smavoltl2') | float | round(2)}}{% endif %}"
        friendly_name: "sma volt L2"
      sma_tensione_l3:
        value_template: "{% if states('sensor.smavoltl3')|float > 1000 %}230{% else %}{{ states('sensor.smavoltl3') | float | round(2)}}{% endif %}"
        friendly_name: "sma volt L3"
      sma_frequenza_di_rete:
        value_template: "{% if states('sensor.smanethz')|float > 1000 %}50{% else %}{{ states('sensor.smanethz') | float | round(2)}}{% endif %}"
        friendly_name: "sma frequenza di rete"
        unit_of_measurement: 'Hz'
      sma_power:
        value_template: "{% if states('sensor.smapwr')|float < 0 %}0{% else %}{{ states('sensor.smapwr') | float | round(2)}}{% endif %}"
        friendly_name: "sma Power"
      sma_total:
        value_template: "{% if states('sensor.smatotal')|float < 0 %}0{% else %}{{ states('sensor.smatotal') | float | round(3)}}{% endif %}"
        friendly_name: "sma Total"
        unit_of_measurement: 'kWh'
      sma_today:
        value_template: "{% if states('sensor.smatoday')|float > 1000 %}0{% else %}{{ states('sensor.smatoday') | float | round(2)}}{% endif %}"
        friendly_name: "sma Today"
      sma_device_type:
        value_template: "{% if states('sensor.smadevtype')|float == 9165 %}SunnyBoy3.6{% else %}?{% endif %}"
        friendly_name: "sma device type"
      sma_grid_relay:
        value_template: "{% if states('sensor.smagridrelay')|float == 51 %}Chiuso{% elif states('sensor.smagridrelay')|float == 311 %}Aperto{% elif states('sensor.smagridrelay')|float == 16777213 %}Spento{% else %}?{% endif %}"
        friendly_name: "sma grid relay"
Thank you very much
Daniele
I’m seeing this same issue on my SMA Tripower 8.0. The inverter reboots once in a while during nighttime. Afterwards the modbus intergration doesn’t start anymore unless I restart my HA instance.
I think this will be fixed in 2021.7.4.
See here: Allow pymodbus to reconnect in running system (not startup) by janiversen · Pull Request #53020 · home-assistant/core · GitHub
Hi Daniele,
Ciao.
I have inverter with modbus, original integration and SMA Energy meter addon.
With the last update the integration and the Energy meter addon doesn’t show me the current house consumption (il consumo della casa istantaneo, che esso sia da grid o da pv o aggregato)
Do you have the sensor working? Is there a way through modbus to have that sensor?
Thank you
Grazie mille!
Hi.
Unfortunately I didn’t have that meter.
I bought a shelly PM, and power from grid a da from/to batteries is measured with this.
With modbus integration I’m able to read data from sma., with last update of core, without any interruption.
I fixed my SMA Modbus configuration and it’s working again:
# Modbus
modbus:
  - type: tcp
    host: 192.168.2.155 # SMA TriPower
    port: 502
    close_comm_on_error: true
    delay: 5
    timeout: 5
    sensors:
      - name: PV_Gesamtertrag
        slave: 3
        address: 30531
        input_type: input
        count: 2
      - name: PV_Leistung
        slave: 3
        address: 30775
        input_type: input
        count: 2
      - name: PV_Tagesertrag
        unit_of_measurement: Wh
        slave: 3
        address: 30517
        count: 4
        data_type: int
      - name: Netzverbrauch
        slave: 3
        address: 30865
        unit_of_measurement: 'W'
        count: 2
        data_type: uint
I hope someone can help me to enable a connection with my SMA Inverter Tripower 15000 and HA. I can connect with Solar Explorer and I have everything enabled. But so far I can’t make a connection with HA and SMA. What do I wrong? See screenshots of my settings.
