MODBUS data from SMA Inverter
check my post, I had the same issue, the format of the configuration changed.
This is what I have right now, after your suggestion in your post.
Modbus
modbus:
  • type: tcp
    host: 192.168.1.22 # SMA TriPower
    port: 502
    close_comm_on_error: true
    delay: 5
    timeout: 5
    sensors:
    • name: PV_totale_opbrengst
      unit_of_measurement: kWh
      slave: 3
      address: 30531
      input_type: input
      count: 2
    • name: PV_Vermogen
      unit_of_measurement: W
      slave: 3
      address: 30775
      input_type: input
      count: 2
    • name: PV_Dagopbrengst
      unit_of_measurement: Wh
      slave: 3
      address: 30517
      count: 4
      data_type: int
      But still the same error after reboot HA. I see the sensors under Entities, but with errors.
If I do a Portscan for IP of my Inverter, than no ports are scanned. Maybe thats the issue? Or do I need to setup a password and username in the configuration.yaml?
No, there’s no need for a username or password using Modbus. The Modbus server is running on your inverter?
Yes I have. Thats the strange thing of it. It looks that evertything is set well.
2021-08-10_08-59-37
The message: This entity (“sensor.smatoday”) does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail. Maybe the Unique ID is something for my problem?
Huge thank you Thorsten for your fixed modbus. Worked for me.
@rbusschner I have the same message but getting values.
sma1sma3
Nice to hear that it works for you. Can you send a sample of your config.yaml? Did you make other changes as well?
If you do a port scan for the inverter ip, is than port 502 open for that?
Found the options to change the State. It’s unavailable.
2021-08-16_13-04-48
Well it work only during daytime, at night time Im getting negative crazy high number. yaml was copy pasted from Thorsten. I am trying now chris_ka setup with node red but having trouble to figure out how to get current solar production out as he has there only total and daily yeild. I’m not coder so I have no idea what to do :slight_smile:
edit: gave up on chris_ka node red setup for now, it works for yield but have no idea how to get out current production. Went back to Thorsten setup but need to figure out what to do about the negative numbers during night.
Posting pics of my yaml.sma yaml
Have you figure this out? I have the same problem and going nuts from it. Thx
Does anyone has the problem with power value from invertor during night? I know some people had but havent seen solution to it. If you sort it out could you please share how?sma night
Hi everyone,
i had from SMA solar all the registers and codes for our inverters.
There are tons of registers that are of no usage and i need someone who can help me to fin the correct registers for all the sensors on the Sma solar inverter UI.
i will share an excel file with anyone who wish to help.
Thank you!
Hello everybody,
I have my modbus sma connection running, but how do I get it to homeassistant energy solar?
Best regards,
Stefan
If you don’t have kWh values, use:
I have a Sunny Boy 5000TL-US-22, S/W Version 02.35.03.R
Here are the settings that are working for me (edited 9/12/21):
modbus:
  - name: sma_hub
    type: tcp
    host: 192.168.1.205
    port: 502
    sensors:
        - name: sma_status
          data_type: int32
          unit_of_measurement: status
          slave: 3
          address: 30201
          count: 2
        - name: sma_power
          data_type: int32
          device_class: 'power'
          slave: 3
          address: 30775
          count: 2
        - name: sma_tempurature
          data_type: int32
          device_class: 'temperature'
          unit_of_measurement: °C
          slave: 3
          address: 30953
          count: 2
          scale: 0.1
        - name: grid_voltage
          data_type: int32
          device_class: 'voltage'
          unit_of_measurement: V
          slave: 3
          address: 30783
          count: 2
          scale: 0.01
          precision: 2
        - name: grid_frequency
          data_type: int32
          unit_of_measurement: Hz
          slave: 3
          address: 30803
          count: 2
          scale: 0.01
          precision: 2
# template to get rid of the wild numbers when the inverter is not producing:
template:
  - sensor:
    - name: "sma_status_template"
      state: "{% if is_state('sensor.sma_status', '35') %} Fault
              {% elif is_state('sensor.sma_status', '303') %} Off
              {% elif is_state('sensor.sma_status', '455') %} Warning
              {% elif is_state('sensor.sma_status', '307') %} OK
              {% else %} Unknown Code
              {% endif %}"
    - name: "sma_power_template"
      unit_of_measurement: "power"
      state: "{% if states('sensor.sma_power') is not none %}
                 {% if states('sensor.sma_power') | int < 0 %}
                    {{ 0 }}
                 {% else %}
                    {{ states('sensor.sma_power') | int }}
                 {% endif %}
               {% else %}
                 {{ 'error' }}
               {% endif %}"
    - name: "sma_tempurature_template"
      unit_of_measurement: "tempurature"
      state: "{% if states('sensor.sma_tempurature') is not none %}
                   {% if states('sensor.sma_tempurature') | int < 0 %}
                      {{ 0 }}
                   {% else %}
                      {{ states('sensor.sma_tempurature') | int }}
                   {% endif %}
               {% endif %}"
    - name: "grid_voltage_template"
      unit_of_measurement: "voltage"
      state: "{% if states('sensor.grid_voltage') is not none %}
                   {% if states('sensor.grid_voltage') | float(default=0) < 0 %}
                      {{ 0 }}
                   {% else %}
                      {{ states('sensor.grid_voltage') | float(default=0) }}
                   {% endif %}
               {% endif %}"
    - name: "grid_frequency_template"
      unit_of_measurement: "frequency"
      state: "{% if states('sensor.grid_frequency') is not none %}
                   {% if states('sensor.grid_frequency') | float(default=0) < 0 %}
                      {{ 0 }}
                   {% else %}
                      {{ states('sensor.grid_frequency') | float(default=0) }}
                   {% endif %}
               {% endif %}"
Whatever I do, I can’t get a connection to my sunny tripower 15000 with modbus connection. I tried you config as wel, but without succes. Any tips or idea’s?
@rbusscher Are you seeing any errors in the log? I see you have the entities, are they logging any data? PS: I made a couple tweaks to my post above, I found some mistakes.
I have a lot of erros like this:
021-09-11 18:56:05 ERROR (SyncWorker_4) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:05 ERROR (SyncWorker_4) [homeassistant.components.modbus.modbus] Pymodbus: sma_hub: Modbus Error: [Connection] Failed to connect[ModbusTcpClient(192.168.1.22:502)]
2021-09-11 18:56:08 ERROR (SyncWorker_1) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:11 ERROR (SyncWorker_3) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:14 ERROR (SyncWorker_4) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:17 ERROR (SyncWorker_2) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:20 ERROR (SyncWorker_1) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
2021-09-11 18:56:23 ERROR (SyncWorker_3) [pymodbus.client.sync] Connection to (192.168.1.22, 502) failed: timed out
Definitely some network connectivity problem. Can you ping the inverter IP from your HA computer? Also, are both your HA device and the SMA are the same network subnet?
Yes, I can ping the Inverter from my HA. But when I do a portscan to the IP address of my inverter, port 502 or other ports aren’t recognized. HA and the inverter are in the same subnet.
No knowing what port scan tool you’re using, know that some only scan “common” ports and would not include port 502. Do you have any firewalls or hardware between your two devices? If they are connected to the same switch, then I suspect you have a problem with the network card in the inverter? Does the inverter report data to SMA? Is that working? Is your inverter a newer one or a few years old. Reason I ask is the newer ones have networking built in and have a web interface. If yours is new and you can’t reach it on port 80 then that’s a big sign somethings up with the network interface on the inverter. The older inverters, like mine, have an add-on network interface box and do not include a web interface. Sorry I’m not much help here. Maybe try powering down your system and restart it?
