Modbus does not update entity status
Tying once again…
Last working verion HA.0114 from then,
modbus is not longer working properly,syntax had changed , once i have update the syntax , commands are sent BUT, status is not being updated .
Did anyone manage to resolve it?
Old settings which are FULLY working on old version:
  type: serial
  method: rtu
  #port: /dev/ttyUSB0
  port: /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_0133D18C-if00-port0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
  timeout: 4
  - platform: modbus
    coils:
    #====================================Module #1=============================
   # First Floor
      - name: Switch01
        slave: 10
        coil: 0
      - name: Switch02
        slave: 10
        coil: 1
      - name: Switch03
        slave: 10
        coil: 2
      - name: Switch04
        slave: 10
        coil: 3
      - name: Switch05
        slave: 10
        coil: 4
      - name: Switch06
        slave: 10
        coil: 5
      - name: Switch07
        slave: 10
        coil: 6
      - name: Switch08
        slave: 10
        coil: 7
New settings -does not update status, nor working with include
  type: serial
  method: rtu
  port: /dev/ttyUSB0
  #port: /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_0133D18C-if00-port0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
  timeout: 4
  retry_on_empty: true
  retries: 10
  message_wait_milliseconds: 100
  switches:
    - name: SW001
      slave: 3
      address: 0
      write_type: coil
    - name: SW002
      slave: 3
      address: 1
      write_type: coil
    - name: SW003
      slave: 3
      address: 2
      write_type: coil
    - name: SW004
      slave: 3
      address: 3
      write_type: coil
    - name: SW005
      slave: 3
      address: 4
      write_type: coil
    - name: SW006
      slave: 3
      address: 5
      write_type: coil
    - name: SW007
      slave: 3
      address: 6
      write_type: coil
    - name: SW008
      slave: 3
      address: 7
      write_type: coil
