I am using a USB2Serial (RS485) adapter to get data from an energy meter, what has worked well for month.
After Updating HA-OS from 12.0 to 12.2 (and HA-Core from 2024.3.3 (not sure) to 2024.4.3), I can’t connect my USB2Serial-Adapter. Everything in HA looks fine, as far as I can see, but I get the following error:
Logger: homeassistant.components.modbus.modbus
Source: components/modbus/modbus.py:318
integration: Modbus (documentation, issues)
First occurred: 15:16:56 (2 occurrences)
Last logged: 15:18:57
Pymodbus: EM_Heizung: Error: device: 0 address: 1024 -> Modbus Error: [Input/Output] ERROR: No response received after 3 retries
Pymodbus: EM_Heizung: Error: device: 0 address: 1056 -> Modbus Error: [Input/Output] ERROR: No response received after 3 retries
I have tried to change from USB0 to USB1, also different baudrates, nothing works.
I have disconnected the USB adapter from the HA and connected it to my Windows PC and read out data from the same device (energy meter), which worked perfectly.
I’m guessing the integration was set-up with you connecting to a specific serial port like
You should be able to set it up using the id of the device instead, then no matter what serial port the OS assigns it to at reboot, it will find it.
I don’t know exactly with that integration, but all the zwave, zigbee, bluetooth integrations I’ve used this works.
I have tried this, but using the ID (in modbus.yaml) does not work and terminates other modbus integrations (tcp) additionally.
I am actually sure that I am using the correct USB port, depending on which one the adapter is currently using (/dev/ttyUSB0 or /dev/ttyUSB1). I think that is not the problem. I am aware of the problem because I also have a Sonoff Zigbee USB adapter in use and sometimes the two switch USB ports. There are no problems with the Sonoff USB-Adapter.
I am also reading data from my energy meter with modbus, in my case I am using USR-DR302 to convert from modbus to TCP and with type: rtuovertcp as modbus in configuration.
And In my situation even after upgrading to 2024.4.4 I still can’t read data from energy meter.
Downgrading to 2024.3.3 fixes it
This is my log file on 2024.4.4:
2024-04-26 19:40:02.114 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: inepro380: Error: device: 0 address: 20482 -> Modbus Error: [Input/Output] ERROR: No response received after 3 retries
2024-04-26 19:40:02.115 DEBUG (MainThread) [pymodbus.logging] Wait comm 100.0 ms before reconnecting.
2024-04-26 19:40:02.146 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: inepro380: Error: device: 0 address: 20484 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 10.10.1.221:23]
2024-04-26 19:40:02.179 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: inepro380: Error: device: 0 address: 20486 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 10.10.1.221:23]
2024-04-26 19:40:02.211 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: inepro380: Error: device: 0 address: 20492 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 10.10.1.221:23]
2024-04-26 19:40:02.266 DEBUG (MainThread) [pymodbus.logging] Connecting to 10.10.1.221:23.
2024-04-26 19:40:02.267 DEBUG (MainThread) [pymodbus.logging] Connecting comm
2024-04-26 19:40:02.273 DEBUG (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: inepro380: Error: device: 0 address: 20494 -> Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 10.10.1.221:23]
2024-04-26 19:40:02.277 DEBUG (MainThread) [pymodbus.logging] Connected to comm
@Iceman03, could you please check it your issue has been fixed with 2024.4.4, please?
Hi
Observing the same issue with ControlByWeb device X410-I. Modbus communication is working fine most of the time, but every few hours, I get: 2024-05-09 11:19:58.003 ERROR (MainThread) [homeassistant.components.modbus.modbus] Pymodbus: modbus_CbW: Error: device: 1 address: 1024 → Modbus Error: [Connection] Not connected[AsyncModbusTcpClient 192.168.2.57:502]
