Modbus heatpump issue configuration Esphome
I have a heat pump boiler with modbus protocol but I can’t communicate with it, I attach my configuration: esphome side:
`esphome:
  friendly_name: ESPHome Web f96b62
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXXXXXXXXXXXXXAlvDLbWdJr3BxhnxchQCfMSQEDrBXPAZBnqs="
ota:
wifi:
  ssid: "XXXXXXXXXXXX"
  password: "XXXXXXXXXXXXXX"
  ap:
    password: "XXXXXXXXXXXX"
captive_portal:
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  stop_bits: 1
  #baud_rate: 115200
modbus:
  uart_id: mod_bus
  #send_wait_time: 200ms
modbus_controller:
# the Modbus device addr
  address: 0x01
  modbus_id: modbus1
  update_interval: 5s
  #setup_priority: -10
  - platform: modbus_controller
    modbus_controller_id: vlb
    register_type: holding
    address: 2001
    value_type: U_WORD`
configuration.yaml:
modbus:
  - name: modbus1
    type: tcp
    host: 192.168.1.6
    port: 502
these are the moddbus addresses of the machine
error no response…
I know it’s been a while since you posted, but I managed to connect using an ESP32 with an RS485 module and set up the following configuration in case someone else needs it.
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  parity: EVEN
  stop_bits: 1
  data_bits: 8
modbus:
modbus_controller:
  - id: heat_pump_modbus
    address: 0x01  ## address of the ModBUS slave device on the bus
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 10s
    command_throttle: 2ms
thanks for the reply, I only saw it now, I’ll try over the weekend, I wanted to ask you again, I have to replace this part of the code you sent with my parameters, in the sense: I have to leave (sensor:) etc. ?
yes, the sensors and other entities remain the same. The code above is only for connecting to the modbus controller.
Here is an example for reading Alarms:
sensors:
### ALARMS
    modbus_controller_id: heat_pump_modbus
    address: 0x00C8
    value_type: U_WORD
    on_value:
      then:
        - lambda: |-
            std::string state;
            switch ((int)id(alarm1_raw).state) {  // Cast to integer
              case 0:
                state = "High pressure - E001";
                break;
              case 1:
                state = "Low pressure - E002";
                break;
              case 2:
                state = "Compressor thermal protection - E003";
                break;
              case 3:
                state = "Fan theral protection - E004";
                break;
              case 4:
                state = "Frost - E005";
                break;
              case 5:
                state = "Lack of flow - E006";
                break;
              case 6:
                state = "ACC prepare low temperature - E007";
                break;
              case 7:
                state = "Lack of librication - E008";
                break;
              case 8:
                state = "High discharge temeperature of Cp 1 - E009";
                break;
              case 9:
                state = "Solar collector at high temperature - E010";
                break;
              case 12:
                state = "Compressor 2 thermal protection - E013";
                break;
              case 13:
                state = "Fan 2 thermal protection - E014";
                break;
              case 15:
                state = "Pump thermal protection - E016";
                break;
              default:
                state = "Unknown";
            id(alarm1).publish_state(state);
Hi @gojonny i’m about to install an i-32V5 heat pump soon, can i ask you where did you find the modbus reference? are you able to share it? if you have the HA implementation working and want to share that too it would be amazing
I didn’t succeed, I thought I had found something on the net but it wasn’t what I needed, someone very kind tried to help me but nothing, so I abandoned the project I even spent a lot of money buying a hs-2211 converter module but nothing I didn’t succeed, I hope that someone can in the future because I need to remotely control my heat pump.
Thank you, if i eventually do something I’ll post an update
Hey, i finally moved in my new home and had time messing with this. I am happy to report that i managed to get (almost) everything working, Here’s a rundown of what i did and the needed config.
oh boy was I in for a ride…
First of all: you can’t connect both the original heatpump remote control and the rs485 interface together,m since modbus is a one-master protocol, so you will need to either:
  • remove the maxa remote panel and only connect your 485 bridge
  • buy a multi-master 485 hub.
I tried getting an hub to retain all the original functionality but was not too lucky the first time.
The hub i bought (the cheapest i found on aliexpress, duh) was a YR-8103 module: After days and days of trying to understand how it works, trying every possible comibation of cabling and software configuration, and trying to deal with the seller (which was a fucking mess) I concluded that it’s not compatible with the maxa modbus, as far as i was able to gather that’s because it doesn’t support configuration of stop bit.
DO NOT buy the YR-8103 rs485 multi master module. it sucks, the software is not available in english, and it has an half assed implementation of the protocol.
The second time (i went with the second most cheaper this time, 5head) i bought a GC-1201s module, and this time i was fortunate enough, the module is able to relay messages from both the original panel and the 485 bridge to the heatpump.
Again, the sellers of this module are not too helpful, but the configuration software (which is detected as a virus by windows, but i think that’s just bad programming) at least has an “english” button which gets you an english interface. The manual is also not available in english, but i’ll attach a machine translated version of it.
You will need to configure the bridge for it to work, as the default config does not have the correct parameters.
to do that you will need a USB to rs485 adapter and a computer with the software mentioned above (and downloadable below)
This is the config you will need to set in the software, for all the ports on the module (2 masters + 1 slave)
  • baud: 9600
  • data bits: 8
  • parity: even
  • stop bits: 1
Now, for everything else.
i used an elfin EW11 to read data from the heatpump, configured like this:
i then used the modbus integration in homeassistant to create sensors and controls for almost everything listed in the spec in the manual, what i tested works, but i’m sure it can be made better, i’m happy to try a revised version if anyone tries!
modbus:
  - name: maxa_rtu_gateway
    type: tcp
    host: 192.168.22.6 # Elfin gateway IP
    port: 502
    timeout: 5
    delay: 1
    message_wait_milliseconds: 200
    # SENSORS – READ-ONLY VALUES                                #
    sensors:
      # firmware registers cause errors, not essential anyways
      # # Firmware / identification
      # - name: "Firmware Version"
      #   slave: 1
      #   address: 1
      #   input_type: holding
      #   data_type: uint16
      # - name: "Firmware Release"
      #   slave: 1
      #   address: 2
      #   data_type: uint16
      # - name: "Firmware Sub-Release"
      #   slave: 1
      #   address: 3
      #   data_type: uint16
      # Serial number (ASCII, 18 × 2-byte holding = 36 chars)
      - name: "Serial Number"
        slave: 1
        address: 80
        input_type: holding
        data_type: string
        count: 18
      # Flow-meter
      - name: "Water Flow Rate"
        slave: 1
        address: 444
        input_type: holding
        data_type: uint16
        unit_of_measurement: "L/min"
        # icon: mdi:water
      # Temperatures (°C, scale 0.1)
      - name: "Water Inlet Temp"
        slave: 1
        address: 400
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        unit_of_measurement: "°C"
      - name: "Water Outlet Temp"
        slave: 1
        address: 401
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "DHW Temp"
        slave: 1
        address: 405
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp Inhalation Temp"
        slave: 1
        address: 422
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Outdoor Temp"
        slave: 1
        address: 428
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp Discharge 1 Temp"
        slave: 1
        address: 433
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp Discharge 2 Temp"
        slave: 1
        address: 434
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp Discharge 3 Temp"
        slave: 1
        address: 435
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Solar Collector Temp"
        slave: 1
        address: 437
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Solar Accumulation Temp"
        slave: 1
        address: 438
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Plant Remote Temp"
        slave: 1
        address: 440
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Radiant Panels Mix Delivery Temp"
        slave: 1
        address: 443
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "DHW Preparer Recirc Temp"
        slave: 1
        address: 447
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Evaporation Temp"
        slave: 1
        address: 253
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Condensation Temp"
        slave: 1
        address: 254
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Evaporation Temp-C2"
        slave: 1
        address: 626
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Condensation Temp-C2"
        slave: 1
        address: 627
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp Inhalation Temp-C2"
        slave: 1
        address: 20422
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp1 Discharge Temp-C2"
        slave: 1
        address: 20433
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp2 Discharge Temp-C2"
        slave: 1
        address: 20434
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Comp3 Discharge Temp-C2"
        slave: 1
        address: 20435
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      # Pressures (bar, scale 0.01)
      - name: "High Pressure"
        slave: 1
        address: 406
        input_type: holding
        data_type: int16
        scale: 0.01
        precision: 2
        unit_of_measurement: "bar"
      - name: "Low Pressure"
        slave: 1
        address: 414
        input_type: holding
        data_type: int16
        scale: 0.01
        precision: 2
      - name: "High Pressure-C2"
        slave: 1
        address: 20406
        input_type: holding
        data_type: int16
        scale: 0.01
        precision: 2
      - name: "Low Pressure-C2"
        slave: 1
        address: 20414
        input_type: holding
        data_type: int16
        scale: 0.01
        precision: 2
      # Analogue outputs (% , scale 0.1)
      - name: "Condensation Fan %"
        slave: 1
        address: 7000
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        unit_of_measurement: "%"
      - name: "Circulating Pump %"
        slave: 1
        address: 7001
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      - name: "Condensation Fan %-C2"
        slave: 1
        address: 628
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
      # Operating hours (h)
      - name: "Compressor 1 Hours"
        slave: 1
        address: 305
        input_type: holding
        data_type: int16
        unit_of_measurement: "h"
      - name: "Compressor 2 Hours"
        slave: 1
        address: 307
        input_type: holding
        data_type: int16
      - name: "Compressor 3 Hours"
        slave: 1
        address: 309
        input_type: holding
        data_type: int16
      - name: "Compressor 1-C2 Hours"
        slave: 1
        address: 313
        input_type: holding
        data_type: int16
      - name: "Compressor 2-C2 Hours"
        slave: 1
        address: 315
        input_type: holding
        data_type: int16
      - name: "Compressor 3-C2 Hours"
        slave: 1
        address: 317
        input_type: holding
        data_type: int16
      # Machine status register (200)
      - name: "Machine Status Raw"
        slave: 1
        address: 200
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 950"
        slave: 1
        address: 950
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 951"
        slave: 1
        address: 951
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 952"
        slave: 1
        address: 952
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 953"
        slave: 1
        address: 953
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 954"
        slave: 1
        address: 954
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 955"
        slave: 1
        address: 955
        input_type: holding
        data_type: uint16
      - name: "Alarm Register 956"
        slave: 1
        address: 956
        input_type: holding
        data_type: uint16
    # CLIMATES – SETPOINTS (READ/WRITE)                          #
    climates:
      # Each climate entity exposes a single setpoint register as a thermostat.
      - name: "Cooling Setpoint"
        slave: 1
        address: 7203
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 5.0
        max_temp: 23.0
        temp_step: 0.1
        target_temp_register: 7203
        temperature_unit: C
      - name: "Heating Setpoint"
        slave: 1
        address: 7204
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 25.0
        max_temp: 55.0
        temp_step: 0.1
        target_temp_register: 7204
        temperature_unit: C
      - name: "Sanitary Setpoint"
        slave: 1
        address: 7205
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 25.0
        max_temp: 55.0
        temp_step: 0.1
        target_temp_register: 7205
        temperature_unit: C
      - name: "Second Cooling Setpoint"
        slave: 1
        address: 7206
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 5.0
        max_temp: 23.0
        temp_step: 0.1
        target_temp_register: 7206
        temperature_unit: C
      - name: "Second Heating Setpoint"
        slave: 1
        address: 7207
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 25.0
        max_temp: 55.0
        temp_step: 0.1
        target_temp_register: 7207
        temperature_unit: C
      - name: "DHW Preparer Setpoint"
        slave: 1
        address: 7208
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        min_temp: 0.0
        max_temp: 80.0
        temp_step: 0.1
        target_temp_register: 7208
        temperature_unit: C
      # MACHINE MODE via climate entity (register 7200)
      - name: "Heat Pump Mode"
        slave: 1
        address: 400 # water inlet temp as current temp feedback
        input_type: holding
        data_type: int16
        scale: 0.1
        precision: 1
        temperature_unit: C
        hvac_mode_register:
          address: 7200
          values:
            state_off: 0 # Standby
            state_cool: 1 # Cooling
            state_heat: 2 # Heating
        target_temp_register: 7203 # primary cooling setpoint for UI control
        min_temp: 5.0
        max_temp: 55.0
        temp_step: 0.1
    # SWITCHES – REMOTE ENABLE / SPECIAL REQUESTS                #
    switches:
      - name: "Remote State Write Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 1 # bit 0 => value 1
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Remote Setpoint Write Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 2 # bit 1 => value 2
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      # 7201 – Enable bits
      - name: "Second Setpoint Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 4 # bit 2 => value 4
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Room Temp Call Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 8 # bit 3 => value 8
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Sanitary Call Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 16 # bit 4 => value 16
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Anti-Legionella Enable"
        slave: 1
        address: 7201
        write_type: holding
        command_on: 32 # bit 5 => value 32
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      # 7202 – Remote commands / requests
      - name: "Second Setpoint Active"
        slave: 1
        address: 7202
        write_type: holding
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Room Temp Call"
        slave: 1
        address: 7202
        write_type: holding
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Sanitary Call"
        slave: 1
        address: 7202
        write_type: holding
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Anti-Legionella Cycle Request"
        slave: 1
        address: 7202
        write_type: holding
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Plant Air-Vent"
        slave: 1
        address: 7202
        write_type: holding
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Sanitary Disabling"
        slave: 1
        address: 7202
        write_type: holding
        command_on: 64 # bit 6
        command_off: 0
        verify:
          input_type: holding
          delay: 1
      - name: "Forced Defrosting"
        slave: 1
        address: 7202
        write_type: holding
        command_on: 128 # bit 7
        command_off: 0
        verify:
          input_type: holding
          delay: 1
    # CLIMATE (OPTIONAL)                                         #
    # Home Assistant’s generic_modbus climate platform can wrap
    # the above setpoint numbers and a mode switch. This is left
    # out to keep the YAML concise – create a climate entity in
    # UI using the Helper → Generic Thermostat if needed.
# TEMPLATE SENSORS
template:
  - sensor:
      - name: "Current Alarm"
        state: >
          {% set regs = [
            states('sensor.alarm_register_950')|int,
            states('sensor.alarm_register_951')|int,
            states('sensor.alarm_register_952')|int,
            states('sensor.alarm_register_953')|int,
            states('sensor.alarm_register_954')|int,
            states('sensor.alarm_register_955')|int,
            states('sensor.alarm_register_956')|int
          {% set alarm_map = [
            (0, 1, "High Pressure"),
            (0, 2, "Low Pressure"),
            (0, 4, "Compressor Thermal"),
            (0, 8, "Fan Thermal"),
            (0, 16, "Frost"),
            (0, 32, "Lack of Flow"),
            (0, 64, "DHW Low Temperature"),
            (0, 128, "Lack of Lubrication"),
            (0, 256, "High Discharge Temp Cp1"),
            (0, 512, "Solar Collector High Temp"),
            (0, 4096, "Compressor 2 Thermal"),
            (0, 8192, "Fan 2 Thermal"),
            (0, 32768, "Pump Thermal"),
            (1, 2, "High Temperature"),
            (1, 4, "High Discharge Temp Cp2"),
            (1, 8, "Inverted Pressure Transducers"),
            (1, 64, "Compressor 3 Thermal"),
            (1, 128, "Fan 3 Thermal"),
            (1, 512, "Pump 2 Thermal"),
            (1, 2048, "Incongruent Temperatures"),
            (1, 4096, "Poor Heat Exchange DHW"),
            (1, 8192, "DHW Accumulation Tank High Temp"),
            (1, 16384, "I/O Module 1 Disconnected"),
            (1, 32768, "I/O Module 2 Disconnected"),
            (2, 1, "Probe 1 Error"),
            (2, 2, "Probe 2 Error"),
            (2, 4, "Probe 3 Error"),
            (2, 8, "Probe 4 Error"),
            (2, 16, "Probe 5 Error"),
            (2, 32, "Probe 6 Error"),
            (2, 64, "Probe 7 Error"),
            (2, 128, "Probe 8 Error"),
            (2, 256, "Probe 9 Error"),
            (2, 512, "Probe 10 Error"),
            (2, 1024, "Probe 11 Error"),
            (2, 2048, "Module 1 Probe 1 Error"),
            (2, 4096, "Module 1 Probe 2 Error"),
            (2, 8192, "Module 1 Probe 3 Error"),
            (2, 16384, "Module 1 Probe 4 Error"),
            (2, 32768, "Module 1 Probe 5 Error"),
            (3, 1, "Module 1 Probe 6 Error"),
            (3, 2, "Module 1 Probe 7 Error"),
            (3, 4, "Module 1 Probe 8 Error"),
            (3, 8, "Module 1 Probe 9 Error"),
            (3, 16, "Module 1 Probe 10 Error"),
            (3, 32, "Module 1 Probe 11 Error"),
            (3, 64, "Module 2 Probe 1 Error"),
            (3, 128, "Module 2 Probe 2 Error"),
            (3, 256, "Module 2 Probe 3 Error"),
            (3, 512, "Module 2 Probe 4 Error"),
            (3, 1024, "Module 2 Probe 5 Error"),
            (3, 2048, "Module 2 Probe 6 Error"),
            (3, 4096, "Module 2 Probe 7 Error"),
            (3, 8192, "Module 2 Probe 8 Error"),
            (3, 16384, "Module 2 Probe 9 Error"),
            (3, 32768, "Module 2 Probe 10 Error"),
            (4, 1, "Module 2 Probe 11 Error"),
            (4, 2, "Link Inverter 1"),
            (4, 4, "Link Inverter 2"),
            (4, 8, "Link Inverter 3"),
            (4, 16, "Hardware Fault Inverter 1"),
            (4, 32, "Hardware Fault Inverter 2"),
            (4, 64, "Hardware Fault Inverter 3"),
            (4, 128, "Overcurrent Inverter 1"),
            (4, 256, "Overcurrent Inverter 2"),
            (4, 512, "Overcurrent Inverter 3"),
            (4, 1024, "High Temp Inverter 1"),
            (4, 2048, "High Temp Inverter 2"),
            (4, 4096, "High Temp Inverter 3"),
            (4, 8192, "Bad Voltage Inverter 1"),
            (4, 16384, "Bad Voltage Inverter 2"),
            (4, 32768, "Bad Voltage Inverter 3"),
            (5, 1, "Phase Sequence Inverter 1"),
            (5, 2, "Phase Sequence Inverter 2"),
            (5, 4, "Phase Sequence Inverter 3"),
            (5, 8, "Model Error Inverter 1"),
            (5, 16, "Model Error Inverter 2"),
            (5, 32, "Model Error Inverter 3"),
            (5, 64, "Overload Inverter 1"),
            (5, 128, "Overload Inverter 2"),
            (5, 256, "Overload Inverter 3"),
            (5, 512, "Overcurrent PFC Inverter 1"),
            (5, 1024, "Overcurrent PFC Inverter 2"),
            (5, 2048, "Overcurrent PFC Inverter 3"),
            (5, 4096, "Internal Comm Error Inverter 1"),
            (5, 8192, "Internal Comm Error Inverter 2"),
            (5, 16384, "Internal Comm Error Inverter 3"),
            (5, 32768, "Fault PFC Inverter 1"),
            (6, 1, "Fault PFC Inverter 2"),
            (6, 2, "Fault PFC Inverter 3"),
            (6, 4, "Probe Error Inverter 1"),
            (6, 8, "Probe Error Inverter 2"),
            (6, 16, "Probe Error Inverter 3"),
            (6, 32, "Abnormal Condition Inverter 1"),
            (6, 64, "Abnormal Condition Inverter 2"),
            (6, 128, "Abnormal Condition Inverter 3"),
            (6, 256, "EEPROM Error Inverter 1"),
            (6, 512, "EEPROM Error Inverter 2"),
            (6, 1024, "EEPROM Error Inverter 3"),
            (6, 2048, "High Discharge Temp Cp3"),
            (6, 4096, "Anti-Legionella Success"),
            (6, 8192, "Anti-Legionella Failed/Stopped"),
          {% set found = namespace(error="OK") %}
          {% for reg_idx, bitmask, name in alarm_map %}
            {% if regs[reg_idx] | int | bitwise_and(bitmask) %}
              {% set found.error = name %}
              {% break %}
            {% endif %}
          {% endfor %}
          {{ found.error }}
      - name: "Machine Status"
        state: >-
          {% set v = states('sensor.machine_status_raw') | int %}
          {% set map = {
            0: 'Standby',
            1: 'Cooling',
            2: 'Heating',
            4: 'Sanitary Only',
            5: 'Cooling + Sanitary',
            6: 'Heating + Sanitary'
          {{ map.get(v, 'Unknown') }}
        icon: mdi:heat-pump
  - select:
      - name: "Machine Mode"
        state: "{{ states('sensor.machine_status') }}"
        options: "{{ ['Standby', 'Cooling', 'Heating', 'Sanitary Only', 'Cooling + Sanitary', 'Heating + Sanitary']}}"
        select_option:
          service: modbus.write_register
            hub: maxa_rtu_gateway
            unit: 1
            address: 7200
            value: >-
              {% set map = {
                'Standby': 0,
                'Cooling': 1,
                'Heating': 2,
                'Sanitary Only': 4,
                'Cooling + Sanitary': 5,
                'Heating + Sanitary': 6
              {{ map[option] }}
        icon: mdi:heat-pump
this config adds a whole bunch of entities to the modbus integration, and also some template sensor to decode the current operating mode (Machine Status) the set mode (Machine Mode) and the active error code description if present (Current Alarm),
To use thiss you should only change the ip address of the elfin module to the actual ip in your network and paste all of this configuration in your configuration.yaml, or add into a file and then import it with something like:
homeassistant:
  packages:
    maxa: !include maxa_modbus.yaml
here’s a peek of it working
If anyone else tries this, please do let me know!, I’m also open to any suggestion for improving the config (and will probably do a follow up if i do some improvements aswell).
Here’s also some useful resources to get into this rabbit hole:
MAXA i-32 controller manual (inlcudes modbus specification)
GC-1201s manual english translated
GC-1201s configuration software NOTE: this WILL be detected as a virus. i’m pretty sure it’s a case of chronically bad chinese programming, but i took precaution when using it and you should too, use at your own risk. Because of virus detection i had to encrypt it to a 7z file for it not to get flagged. the password for the file is 1234
Hi there, I know it’s been a while since this has been posted. I’ve recently setup my own home assistant and was looking to integrate my heat pump. I did as you suggested, copied the yaml and changed the IP address to that of my waveshare rs485-WiFi, but I get the following error message once home assistant reboots
Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘baudrate’ not provided, please check the docs at Modbus - Home Assistant Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘bytesize’ not provided, please check the docs at… Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘method’ not provided, please check the docs at… Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘parity’ not provided, please check the docs at… Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘port’ not provided, please check the docs at… Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘stopbits’ not provided, please check the docs at Modbus - Home Assistant Invalid config for ‘modbus’ at configuration.yaml, line 12: required key ‘type’ not provided, please check the docs at…
Did this happen to you too or do you know what I could have entered wrongly?
The error you have seems to suggest your modbus integration is initialized with type: serial instead of type: tcp. are you sure you copied the yaml correctly and don’t have other instances of modbus: declared in your config?
I don’t have a Maxa i32v5, but an AR Therm AR MB which is exactly the same just rebranded, so your yaml gave me the perfect baseline for mine. I had made a mistake writing the modbus yaml, once I figured out what was wrong I managed to fix it and get it all up and running. With some help from AI I also managed to create a detailed dashboard with stats, COP and some automations that I still need to test. It’s still a work in progress and I only use the heat pump for climate, so I’ll need to tweak and remove some lines from my yaml as I don’t need the DHW, legionella function etc. For now I’ve only enabled heating/cooling - on/off functions.
Sorry for the late reply, with the Christmas holidays and all I’ve been quite busy and thanks again!
I’ll test and tweak my config for a while and if all works I’ll share what I’ve been able to achieve!
Happy new year! :confetti_ball:
To be fair, i don’t use most of the stuff either, but since the modbus protocol was there on the manual, i decided to implement all i could so i could post a complete integration, you can always disable entities in HA if you don’t want to tweak the yaml. In any case, glad i could be of help
Hello Fabio, can you post some pictures of the hardware and wirings ?
I’ve recently got a new Maxa i-32v5 16kW and I’d like to integrate it in HA too
Hi, it’s kinda hard for me to open up the heatpump now to take photos, but the manual should have all the information you need. If you need, you can post a photo of the terminal block on your machine, or just ask about a specific problem you’re having.
the terminals you need to use are in the user installer manual, page 27
you need to use the same modbus pins to which the remote keyboard is connected to.
i didn’t even have to open up the heatpump: the installer mounted the keyboard inside, and i just disconnected the modbus cables from there and hooked them up to the multi master hub (you have to do this anyway, since you can not retain the original heatpump → keyboard connection when installing a modbus bridge for HA)
Would this recent add-on assist?
seems awesome, not really looking forward to try and configure it right now, since the yaml version seem to work fine for now, but thanks for sharing, i will be definetly using that in the future
I’m following, I’m interested
As I said, i’m not gonna take photos since i’m not going to open up the heatpump anytime soon, if you need help with something else specific, i can try to help, but following my instructions + the manual should make it easy enough.
in any case, a photo of the inside of the machine would just show the terminal block with wires going out from terminals x4.1 x5.1 and x5.2 and going in a conduct to a different room :slight_smile:
I have even improved beyond that with the protocol wizard. Support both Modbus and SNMP. More protocols to come on demand. The architecture is now fully ready to add any protocol! (GitHub - partach/protocol_wizard: The Protocol Wizard helps you build your home assistant devices without need for any yaml!)
I will update the post refered with this info.
Just released a first version safe to try and includs correct template for waveshare (at lease the 8Ch relay and digital 8Ch input). Also SNMP templates supported! These templates make it easy to add any device for any protocol supported :slight_smile:
