I got it! I’ve tried so many things, but i think in my case TX goes to TX and RX to RX… I watched some obscure Indian video on Youtube and found that this is the case with the RS485 to TTL i have.
This is my Yaml. I actually copied it from @kitt2011 comment. The one listed in the project wouldn’t compile for me.
The supplied .H file works fine though.
esphome:
comment: "Solar Charge Controller"
includes:
- ampinvt.h
esp32:
board: esp32dev
framework:
version: recommended
type: arduino
logger:
baud_rate: 0
level: DEBUG
wifi:
ssid: Brown Haus 2G
password: Forreston1
reboot_timeout: 8hours
ap:
ssid: "${devicename}"
password: fallback_password
manual_ip:
static_ip: 192.168.1.100
gateway: 192.168.1.1
subnet: 255.255.255.0
use_address: 192.168.1.100
captive_portal:
api:
encryption:
key: uhKxfrQ8TOE+EpHHJZnas0YINhTkx3RQH2aSp6+gXTY=
ota:
- platform: esphome
password: Netpass1.
port: 8266
uart:
tx_pin: 17 # Yellow Wire - MPPT UART Transmit
rx_pin: 16 # Green Wire - MPPT UART Receive
rx_buffer_size: 2048
baud_rate: 9600
parity: NONE
stop_bits: 1
debug:
time:
- platform: homeassistant
on_time:
- seconds: 0,30
then:
- uart.write: [ 0x01, 0xB3, 0x01, 0x00, 0x00, 0x00, 0x00, 0xB5 ] # Reads only real-time data
# - uart.write: [ 0x01, 0xB2, 0x01, 0x00, 0x00, 0x00, 0x00, 0xB4 ] # Reads only parameter settings
- platform: custom
lambda: |-
auto ampinvtsensors = new ampinvtsensor(id(uart_bus));
App.register_component(ampinvtsensors);
return {\
ampinvtsensors->ampinvt_op_status, \
ampinvtsensors->ampinvt_battery_status, \
ampinvtsensors->ampinvt_fan_status, \
ampinvtsensors->ampinvt_overheat_status, \
ampinvtsensors->ampinvt_dcoutput_status, \
ampinvtsensors->ampinvt_inttemp1_status, \
ampinvtsensors->ampinvt_inttemp2_status, \
ampinvtsensors->ampinvt_exttemp_status, \
ampinvtsensors->ampinvt_chg_status, \
ampinvtsensors->ampinvt_equalchg_status, \
ampinvtsensors->ampinvt_track_status, \
ampinvtsensors->ampinvt_floatchg_status, \
ampinvtsensors->ampinvt_chgcurrentlimit_status, \
ampinvtsensors->ampinvt_chgderating_status, \
ampinvtsensors->ampinvt_remoteprohibchg_status, \
ampinvtsensors->ampinvt_pvovervolt_status, \
ampinvtsensors->ampinvt_chgoutputrelay_status, \
ampinvtsensors->ampinvt_loadoutput_status, \
ampinvtsensors->ampinvt_fanrelay_status, \
ampinvtsensors->ampinvt_overchgprotect_status, \
ampinvtsensors->ampinvt_overvoltprotect_status, \
ampinvtsensors->ampinvt_pv_voltage, \
ampinvtsensors->ampinvt_battery_voltage, \
ampinvtsensors->ampinvt_charge_current, \
ampinvtsensors->ampinvt_mppt_temperature, \
ampinvtsensors->ampinvt_battery_temperature, \
ampinvtsensors->ampinvt_today_yield, \
ampinvtsensors->ampinvt_generation_total, \
sensors:
- name: "Operating Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_op_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_op_status_text_sensor).publish_state("Abnormal");
- name: "Battery Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_battery_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_battery_status_text_sensor).publish_state("OD Protection On");
- name: "Fan Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_fan_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_fan_status_text_sensor).publish_state("Fan Failure");
- name: "Overheat Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_overheat_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_overheat_status_text_sensor).publish_state("OT Protection On");
- name: "DC Output Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_dcoutput_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_dcoutput_status_text_sensor).publish_state("DC Output Short");
- name: "Internal Temperature 1 Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_inttemp1_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_inttemp1_status_text_sensor).publish_state("Fault");
- name: "Internal Temperature 2 Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_inttemp2_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_inttemp2_status_text_sensor).publish_state("Fault");
- name: "External Temperature Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_exttemp_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_exttemp_status_text_sensor).publish_state("Fault");
- name: "Charging Status"
icon: mdi:battery-charging
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_chg_status_text_sensor).publish_state("Not Charging");
else {
id(ampinvt_chg_status_text_sensor).publish_state("Charging");
- name: "Equal Charging Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_equalchg_status_text_sensor).publish_state("Not Equalising");
else {
id(ampinvt_equalchg_status_text_sensor).publish_state("Equalising");
- name: "MPPT Tracking Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_track_status_text_sensor).publish_state("Not Tracking");
else {
id(ampinvt_track_status_text_sensor).publish_state("Tracking");
- name: "Float Charging Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_floatchg_status_text_sensor).publish_state("Not Float Charging");
else {
id(ampinvt_floatchg_status_text_sensor).publish_state("Float Charging");
- name: "Charge Current Limit Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_chgcurrentlimit_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_chgcurrentlimit_status_text_sensor).publish_state("Charge Current Limit");
- name: "Charge Derating Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_chgderating_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_chgderating_status_text_sensor).publish_state("Charge Derated");
- name: "Remote Prohibit Charging Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_remoteprohibchg_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_remoteprohibchg_status_text_sensor).publish_state("Remote denial");
- name: "Panel Overvoltage Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_pvovervolt_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_pvovervolt_status_text_sensor).publish_state("PV Overvoltage");
- name: "Charging Output Relay Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_chgoutputrelay_status_text_sensor).publish_state("Closed");
else {
id(ampinvt_chgoutputrelay_status_text_sensor).publish_state("Open");
- name: "Load Output Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_loadoutput_status_text_sensor).publish_state("Closed");
else {
id(ampinvt_loadoutput_status_text_sensor).publish_state("Open");
- name: "Fan Relay Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_fanrelay_status_text_sensor).publish_state("Closed");
else {
id(ampinvt_fanrelay_status_text_sensor).publish_state("Open");
- name: "Overcharge Protection Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_overchgprotect_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_overchgprotect_status_text_sensor).publish_state("Overcharge Protection On");
- name: "Overvoltage Protection Status"
on_value:
then:
- lambda: |-
if(x==0) {
id(ampinvt_overvoltprotect_status_text_sensor).publish_state("Normal");
else {
id(ampinvt_overvoltprotect_status_text_sensor).publish_state("Overvoltage Protection On");
- name: "Solar Panel Voltage"
unit_of_measurement: V
accuracy_decimals: 1
icon: mdi:flash
filters:
- multiply: 0.1
- name: "Solar Battery Voltage"
accuracy_decimals: 2
icon: mdi:flash
filters:
- multiply: 0.01
- name: "Solar Charge Current"
unit_of_measurement: A
icon: mdi:current-dc
filters:
- multiply: 0.01
- name: "Solar Controller Internal Temperature"
unit_of_measurement: °C
filters:
- multiply: 0.1
- name: "Solar Battery Temperature"
filters:
- multiply: 0.1
- name: "Solar Daily Yield"
unit_of_measurement: W
icon: mdi:solar-power
- name: "Solar Total Yield"
unit_of_measurement: KW
device_class: energy #for use in energy dashboard
state_class: total_increasing #for use in energy dashboard
filters:
- multiply: 0.001
text_sensor:
name: "Ampinvt Operating Status"
name: "Ampinvt Battery Status"
name: "Ampinvt Fan Status"
name: "Ampinvt Overheat Status"
name: "Ampinvt DC Output Status"
name: "Ampinvt Internal Temp #1 Status"
name: "Ampinvt Internal Temp #2 Status"
name: "Ampinvt External Temperature Status"
name: "Ampinvt Charging Status"
name: "Ampinvt Equalising Status"
name: "Ampinvt MPPT Tracking Status"
name: "Ampinvt Float Charging Status"
name: "Ampinvt Charge Current Limit Status"
name: "Ampinvt Charge Derating Status"
name: "Ampinvt Remote Prohib Status"
name: "Ampinvt Panel Overvoltage Status"
name: "Ampinvt Charging Output Relay Status"
name: "Ampinvt Load Output Status"
name: "Ampinvt Fan Relay Status"
name: "Ampinvt Overcharge Protection Status"
name: "Ampinvt Overvoltage Protection Status"
switch:
- platform: restart
name: "Solar Controller Restart"
