Modbus Integration - add an ability to use different function codes in climate platform
Real life example: I have a ventilation unit made by Nilan, very popular brand in Scandinavia. I use Modbus Integration to read sensors and change states on it. However, Modbus implementation in this device allows to write registers with function code 16 (0x10) only, for both single register or an array.
Function code 0x10 for write register can be called by using a configuration variabel write_type: holdings , but only in platforms:
  • switch
  • fan
  • light
Or by using service modbus.write_register with array as value.
There is no option to use function code 0x10 in climate platform.
I think it should be quite straightforward to implement configuration variable write_type: holdings in climate platform, for:
  • target_temp_register
  • hvac_mode_register
  • hvac_onoff_register
since is already implemented in others platroms.
So, configuration could look like this:
modbus:
  - name: hub1
    type: tcp
    host: IP_ADDRESS
    port: 502
    climates:
      - name: "Bedroom Air Condition"
        address: 10
        target_temp_register: 10
        write_type: holdings    # New feature
        hvac_mode_register:
          address: 11
          values:
            auto: 0
            cool: 1
            heat: 2
            fan_only: 3
            dry: 4
        hvac_onoff_register: 11
I have the exact same issue. Found a workaround ?
I din’t used more time to dig in it. So mine workaround is a bunch of automation, which triggering service modbus.write_register with array as value, when I need to change something. I don’t use climate integration on Modbus right now.
Here is a example of temperature setpoint automation. Its controlled by a helper (input_number).
alias: NILAN - Temp Setpoint
description: Nilan Temperature Setpoint
  - platform: state
    entity_id: input_number.nilan_set_point
  - service: modbus.write_register
      hub: nilanhub
      unit: 30
      address: 1004
      value: "[{{states('input_number.nilan_set_point') | int }}00, 0]"
I think that this topic could be marked as solved.
The feature requested is available using the parameter write_registers as described into the documentation.
Yep, it has been added. Problem solved :slight_smile:
