Modbus integration. Not showing in integrations
Hi all,
I am new in Hassio and I have a question related to Modbus integration though I think it may happen with all 3rd party integrations (https://www.home-assistant.io/integrations/modbus/)
I am using VMDK virtual image with VirtualBox. That’s fine, it’s working.
I have installed Modbus integration by copying the files in config\custom_components\modbus using SAMBA addon. That’s fine.
I have configured my configuration.yaml including this as a test
modbus:
  type: tcp
  host: 192.168.0.1
  port: 502
binary_sensor:
  - platform: modbus
    scan_interval: 5
    inputs:
      - name: Sensor1
        hub: hub1
        slave: 1
        address: 0
1.) Everything is working but I receive a message in the register that says
Logger: pymodbus.client.asynchronous
Source: custom_components/modbus/init.py:5
Not Importing deprecated clients. Dependency Twisted is not Installed
What does it means?
  1. If I click in Configuration - Integrations - Add, I cannot see the Modbus integration. Is it expected because it’s a 3rd party integration?
  2. When I go to entities i can see my “Sensor1”. How can I assign this sensor to an area?
Thanks a lot!
Marcos.
Any clue? Thanks!
0.106.6 was the last version where Modbus worked properly for me. I get the same error message
