Modbus integration should support "devices"
in the upcomming 2024.8. version, we will get the integration created via configuration.yaml into the Integrations-Page.
As you can see, my Modbus-configuration includes 26 Entities at all.
Now, it would be logical, that the yaml configuration would also support “Devices”
The configuration already has relevant information:
# DEVICE 1
  - name: "DEVICE_NAME_1"
    type: tcp
    host: 192.168.0.1
    port: 503
    lights:
# DEVICE 2
  - name: "DEVICE_NAME_2"
    type: tcp
    host: 192.168.0.2
    port: 503
    lights:
It would be great, if the integration would now show the amount of devices and how many entities there are per device.
duplicate of:
You could use Device Tools from HACS to group entities into virtual devices.
thanks for the suggestion :slight_smile:
Yes, could be a solution or workaround - but I think, this should be a core-topic in the end, as the information is already available in the modbus-configuration :slight_smile:
