fkaresz
(Fogarassy Károly)
November 18, 2023, 7:25pm
1
Hello All!
I would like to configure a modbus.yaml. The definition is this:
modbus:
type: serial
port: /dev/ttyUSB0
baudrate: 9600
bytesize: 8
parity: N
stopbits: 1
timeout: 2
I linked the modbus.yaml in configuration.yaml. If I want to reload the configuration.yaml, the following error message I become:
Failed to reload configuration
‘type’
Do you have any ide, how to solve this?
Thanx
i think you have to remove the ’ in the name.
Example:
modbus:
- name: hub1
type: serial
port: /dev/ttyUSB0
baudrate: 9600
bytesize: 8
parity: N
stopbits: 1
timeout: 2
fkaresz
(Fogarassy Károly)
November 19, 2023, 5:26am
3
Thank you,. I removed the ‘ but the error message is the same
fkaresz
(Fogarassy Károly)
November 19, 2023, 9:33am
4
The log file contains the following:
File “/usr/src/homeassistant/homeassistant/components/modbus/validators.py”, line 283, in duplicate_modbus_validator
if hub[CONF_TYPE] == SERIAL:
do you have any ide, where should I make a correction?
Your configuration.yaml looks like that ?:
modbus: !include modbus.yaml
Then delete your first line in modbus.yaml with “modbus:”
