I have HA 2025.12.3 on haos 16.3 on a raspberry pi 5.
I have a Waveshare USB to RTU converter.
The modbus interface is defined as:
# modbus
modbus:
- name: modbus_hub
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
bytesize: 8
parity: N
stopbits: 1
delay: 0
message_wait_milliseconds: 80
timeout: 1
The various inputs are defined in the section “sensors:” They are provided by independant h/w devices and work okay. I can read the data and visualize it.
Also, I can write to the digital outputs defined in the section “switches:” and the attached Unipy xS51 device responds accordingly.
Now this same xS51 device has several analog outputs (16 bit registers). When I configure them using:
# analog outputs
registers:
# Unipi xS51 @0x05 LV1 (Analog Output 0-10V, controlled as 0-100% in UI)
- name: LV1
slave: 5
address: 2
write_type: holding
data_type: uint16
min_value: 0
max_value: 100
unit_of_measurement: "%"
the corresponding entities do not show up in the page: http://homeassistant.local:8123/config/entities
I test if the path from edit-to-page works, by renaming a resource in the section “switches:” and I see the entity change.
Now: what could be wrong with the section “registers:”?
I’d love to see your response…
Thanks in advance from Netherlands!
