Modbus issue in config. yaml
HA Version 2025.1.3
I get an error when modbus gets activated in configuration yaml.
Pls see config yaml:
Loads default set of integrations. Do not remove.
default_config:
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
modbus: !include modbus.yaml
homeassistant:
packages: !include_dir_named packages
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
ip_ban_enabled: true
login_attempts_threshold: 5
Konfigurationsfehler
Error loading /config/configuration.yaml: in “/config/configuration.yaml”, line 11, column 9: Unable to read file /config/modbus.yaml
