I have spent a lot of time trying to get a simple light over modbus working using a toggle button. (I just want to be able to turn it on and off)
I have been able to create two seperate buttons that work manually:
type: button
tap_action:
action: call-service
service: modbus.write_register
service_data:
address: 4434
unit: 1
value: 1 (0 for the button that shutsoff)
hub: SmartHouse
target: {}
entity: ''
I have also been able to create a sensor that shows if it is turned on or off.
modbus:
- name: SmartHouse
type: tcp
host: 192.168.5.88
port: 502
sensors:
- name: "Light"
address: 4434
slave: 1
data_type: uint16
input_type: holding
scan_interval: 1
However I cannot get it to work as a light instead, have tried:
modbus:
- name: SmartHouse
type: tcp
host: 192.168.5.88
port: 502
lights:
- name: "light1"
address: 4434
write_type: holding
But when I try to add light1 as a light to the dashboard, it does not work. It looks like it is on from the beginning, and when I click it, it says off for a little time and does nothing… It do not affect the light in anyway whether it is turned on or off.
