Hello together,
I’m setting up a fully Modbus controlled HVAC system in Germany (getting a little hot in here). Using oModbusMaster I can set and read holding registers over my setup successfully.
Here it is:
- 5x Futjitsu UTY-VMSX
- 1x WaveShare DIN-Rail RS485 to ETH gateway
I have configured the gateway to conduct the RTU to Modbus-TCP conversion and happily am using it from my Mac Modbus client that way (checked for framing issues).
Sadly with my homeassistant config it does not work
I am looking for hints to further debug it!
Here is my minimal config to check I can control one register first:
- name: "waveshare"
type: tcp
host: 172.16.1.59
port: 502
delay: 10
switches:
- name: "wozi_power"
unique_id: "modbus_wozi_power"
slave: 1
address: 3
command_on: 2
command_off: 1
verify:
- name: "schlafz_power"
unique_id: "modbus_schlafz_power"
slave: 2
address: 3
command_on: 2
command_off: 1
verify:
This means my HVAC is set to on with a value of 2 and off with a value of 1.
Here is what I get from debug logging when flipping the Switch under entities in the GUI:
2024-11-10 08:15:21.047 DEBUG (MainThread) [pymodbus.logging] Adding transaction 111
2024-11-10 08:15:21.047 DEBUG (MainThread) [pymodbus.logging] Resetting frame - Current Frame in buffer -
2024-11-10 08:15:21.047 DEBUG (MainThread) [pymodbus.logging] send: 0x0 0x6f 0x0 0x0 0x0 0x6 0x1 0x6 0x0 0x3 0x0 0x2
2024-11-10 08:15:21.084 DEBUG (MainThread) [pymodbus.logging] recv: 0x0 0x6f 0x0 0x0 0x0 0x6 0x1 0x6 0x0 0x3 0x0 0x2 old_data: addr=None
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Processing: 0x0 0x6f 0x0 0x0 0x0 0x6 0x1 0x6 0x0 0x3 0x0 0x2
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Factory Response[WriteSingleRegisterResponse': 6]
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Getting transaction 111
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Very short frame (NO MBAP): wait for more data
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Adding transaction 112
2024-11-10 08:15:21.085 DEBUG (MainThread) [pymodbus.logging] Resetting frame - Current Frame in buffer -
2024-11-10 08:15:21.086 DEBUG (MainThread) [pymodbus.logging] send: 0x0 0x70 0x0 0x0 0x0 0x6 0x1 0x3 0x0 0x3 0x0 0x1
2024-11-10 08:15:21.087 DEBUG (MainThread) [pymodbus.logging] recv: 0x0 0x70 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0x2 old_data: addr=None
2024-11-10 08:15:21.087 DEBUG (MainThread) [pymodbus.logging] Processing: 0x0 0x70 0x0 0x0 0x0 0x5 0x1 0x3 0x2 0x0 0x2
2024-11-10 08:15:21.087 DEBUG (MainThread) [pymodbus.logging] Factory Response[ReadHoldingRegistersResponse': 3]
2024-11-10 08:15:21.087 DEBUG (MainThread) [pymodbus.logging] Getting transaction 112
**2024-11-10 08:15:21.087 DEBUG (MainThread) [pymodbus.logging] Very short frame (NO MBAP): wait for more data**
I seem to read from this log that HA is sending the required 2 to the gateway and receives confirmation. However, the HVAC with slave 1 is not turned on and does not switch the holding register 40003 to 2.
Is there any debugging you can recommend to me?
Best
