finally i was able to get HA to work but all modbus lines are not working… same files of configuration
any idea???
any idea???
Hello everybody,
I have the same problem. Before 108 everything went smoothly.
# USB-Modbus Schnittstelle
modbus:
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
Someone a solution or is this a bug?
Best wishes
Michael
Hi same with me. Modbus seems broken in 0.108 before in worked perfectly.
There were fixes in 0.108.2
Fix modbus default delay (@janiversen - #33877) (modbus docs)
The new default delay is 0.
delay
(integer)(Optional)
Time to sleep in seconds after connecting and before sending messages. Some modbus-tcp servers need a short delay typically 1-2 seconds in order to prepare the communication. If a server accepts connecting, but there is no response to the requests send, this parameter might help.
Default value:
0
My modbus integration looked like this
modbus:
type: tcp
host: 192.168.178.101
port: 502
Unfortunately after adding the delay parameter with 1 or 2 doesn’t help. I get the following errors:
Logger: pymodbus.factory
Source: __main__.py:342
First occurred: 11:26:58 (6 occurrences)
Last logged: 11:29:32
Unable to decode response Modbus Error: Unknown response 59
Unable to decode response Modbus Error: Unknown response 90
Unable to decode response Modbus Error: Unknown response 125
index out of range
Logger: homeassistant.core
Source: /usr/src/homeassistant/homeassistant/core.py:144
Error doing job: Fatal error: protocol.data_received() call failed.
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 826, in _read_ready__data_received
self._protocol.data_received(data)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 192, in data_received
self._dataReceived(data)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 139, in _dataReceived
self.framer.processIncomingPacket(data, self._handleResponse, unit=unit)
File "/usr/local/lib/python3.7/site-packages/pymodbus/framer/socket_framer.py", line 165, in processIncomingPacket
self._process(callback, error=True)
File "/usr/local/lib/python3.7/site-packages/pymodbus/framer/socket_framer.py", line 175, in _process
raise ModbusIOException("Unable to decode request")
pymodbus.exceptions.ModbusIOException: Modbus Error: [Input/Output] Unable to decode request
I have same problem from 108 release. Updated to 108.3 not helped… Please, help!
Same here. Also invalid config with serial setup. Running 108.3
I have same problem from 108.3. I trying downgrade for 107.7
Its works!
ha core update --version=0.107.7
Works for me as well I am using raspbian not haos
here my error log:
2020-04-11 03:00:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component modbus
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 139, in async_setup
await hass.async_add_executor_job(start_modbus)
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 111, in start_modbus
client.setup()
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 207, in setup
loop=self._loop,
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/serial.py", line 75, in __new__
yieldable = factory_class(framer=framer, port=port, **kwargs)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/factory/serial.py", line 104, in async_io_factory
client = AsyncioModbusSerialClient(port, proto_cls, framer, loop, **kwargs)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 689, in __init__
self._connected_event = asyncio.Event()
File "/usr/local/lib/python3.7/asyncio/locks.py", line 249, in __init__
self._loop = events.get_event_loop()
File "/usr/local/lib/python3.7/asyncio/events.py", line 644, in get_event_loop
% threading.current_thread().name)
RuntimeError: There is no current event loop in thread 'SyncWorker_18'.
greetings
Michael
Yes modbus is definitely broken in 0.108 1-3
I stay on 0.108.3 but I switched to NodeRed and MQTT to retrieve my modbus data.
everything works now again.
I wrote a tutorial how to do this
