frekr
March 30, 2022, 10:11pm
1
I have the following Modbus RTU Relay unit (Protocol Manual of Modbus RTU Relay - Waveshare Wiki ) that integrates 8 switches that are controlled using simple WRITE COIL registers (one for each of the 8 switches). This control can be easily implemented in HA using switches. Unfortunately to get the status of a single switch, there are no dedicated READ COIL registers but just a single COIL register (Address: 0x00FF) which exposes (in a byte) all the 8 switch states i.e. bit0 identifies switch 0 state (if set to â1â switch 0 is on, if set to â0â switch 0 is off) and so on.
In HA verify function for switches cannot be used due to the fact that it is possible to define a single value for the âoffâ state (state_off) and another one for the âonâ state (state_on).
Do you have any suggestion on how to implement such verify functionality?
Andrea
jeanp56
(jean_pol)
May 18, 2022, 3:45pm
2
I have the same problem as you. I donât know how to retrieve relay states from waveshare. Did you find a solution ?
Jean Paul
frekr
May 22, 2022, 5:29pm
3
unfortunately I was not getting any answer so I donât know yet how to get rid of this problemâŠsince modbus implementation relies on pymodbus==1.2.0, we should find a way to customize a new command following this example Custom Message Example â PyModbus 3.0.0.dev3 documentation but I donât know how to integrate it into HA
jeanp56
(jean_pol)
May 23, 2022, 3:12pm
4
Thanks for the informations, Iâll see if I understand anythingâŠ
On my side, I found other relays (like Waveshare) which have status returns that HA can display:
They work very well, I have an 8 relayâŠ
Jean Paul
Ardaganbao
(Ardaganbao)
February 3, 2023, 9:59pm
5
Hello
any solution was found for this issue ? (or behaviour) ?
frekr
March 2, 2023, 8:11am
6
Hi, Iâm currently workaround this by implementing a fastapi python program able to use pymodbus as basis and doing the âcoilâ selection within the read byte based on selected switch. The program is reading exact yaml format of HA, but I added on verify item the new attribute bit in order to identify the bit position like this:
/config/devices/sensors/modbus/waveshare/RELAY.yam
slave: 1
address: 0
write_type: coil
timeout: 2
verify:
address: 255
input_type: coil
bit: 0
slave: 1
address: 0
write_type: coil
timeout: 2
verify:
address: 255
input_type: coil
bit: 1
shubham030
(Shubham Gupta)
March 15, 2024, 2:49pm
7
I am also stuck with same problem, any updates on this?
any news with this problem?
Kymc0
May 26, 2024, 8:51pm
9
HĂ© Guys,
Iâm not sure if this is helpful but I have that Waveshare 8 port relay working fine. This is how I get the status of all coils:
modbus:
- name: hub1
type: tcp
host: 192.168.x.x
port: 502
binary_sensors:
- name: my_relay
address: 0
input_type: coil
slave: 1
slave_count: 7
unique_id: my_relay
They show up at my dashboard as: my_relay_1 to 7. You could add a device class as well.
This is my config with nodered: with switch verify
Modbus [001].json
Kymc0
May 27, 2024, 7:07pm
11
So today through templating I created the switches with feedback. There is probably a smarter way to do this. But this works
modbus:
- name: Waveshare_relay
type: tcp
host: 192.168.x.x
port: 502
binary_sensors:
- name: Relay_sensors
address: 0
input_type: coil
scan_interval: 2
slave: 1
slave_count: 7
unique_id: Relay_sensor
lights:
- name: "light_1"
address: 0
write_type: coil
slave: 1
unique_id: my_relay_1
- name: "light_2"
address: 1
write_type: coil
slave: 1
- name: "light_3"
address: 2
write_type: coil
slave: 1
- name: "light_4"
address: 3
write_type: coil
slave: 1
- name: "light_5"
address: 4
write_type: coil
slave: 1
- name: "light_6"
address: 5
write_type: coil
slave: 1
- name: "light_7"
address: 6
write_type: coil
slave: 1
- name: "light_8"
address: 7
write_type: coil
slave: 1
switch:
switches:
mb_switch1:
value_template: "{{ is_state('binary_sensor.relay_sensors', 'on') }}"
unique_id: mb_switch1
turn_on:
service: light.turn_on
entity_id: light.light_1
turn_off:
service: light.turn_off
mb_switch2:
value_template: "{{ is_state('binary_sensor.relay_sensors_1', 'on') }}"
unique_id: mb_switch2
turn_on:
entity_id: light.light_2
turn_off:
mb_switch3:
value_template: "{{ is_state('binary_sensor.relay_sensors_2', 'on') }}"
unique_id: mb_switch3
turn_on:
entity_id: light.light_3
turn_off:
mb_switch4:
value_template: "{{ is_state('binary_sensor.relay_sensors_3', 'on') }}"
unique_id: mb_switch4
turn_on:
entity_id: light.light_4
turn_off:
mb_switch5:
value_template: "{{ is_state('binary_sensor.relay_sensors_4', 'on') }}"
unique_id: mb_switch5
turn_on:
entity_id: light.light_5
turn_off:
mb_switch6:
value_template: "{{ is_state('binary_sensor.relay_sensors_5', 'on') }}"
unique_id: mb_switch6
turn_on:
entity_id: light.light_6
turn_off:
mb_switch7:
value_template: "{{ is_state('binary_sensor.relay_sensors_6', 'on') }}"
unique_id: mb_switch7
turn_on:
entity_id: light.light_7
turn_off:
mb_switch8:
value_template: "{{ is_state('binary_sensor.relay_sensors_7', 'on') }}"
unique_id: mb_switch8
turn_on:
entity_id: light.light_8
turn_off:
You will end up with 8 switches called mb_switch1 to 8. Who will represent the actual state of the âswitchâ.
pspot2
(Pspot2)
July 16, 2024, 11:59pm
12
Below is my version of this implementation. The idea was taken from Kymc0âs implementation, but mine is a bit shorter and is fully synchronous (does not require polling of the status).
The Modbus part:
modbus:
- name: <your_modbus_converter>
<your_modbus_converter_config>
binary_sensors:
- name: Waveshare relay status
address: 0x0000
input_type: coil
scan_interval: 0
slave: 0x01
slave_count: 7
unique_id: waveshare_relay_sensor
sensors:
- name: Waveshare relay current device address
slave: 0x01
input_type: holding # 0x03
address: 0x4000
data_type: uint16
scan_interval: 0
- name: Waveshare relay software version
slave: 0x01
address: 0x8000
data_type: uint16
scale: 0.01
offset: 0
precision: 2
scan_interval: 0
switches:
- name: Waveshare relay channel 1
slave: 0x01
address: 0x0000
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 2
slave: 0x01
address: 0x0001
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 3
slave: 0x01
address: 0x0002
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 4
slave: 0x01
address: 0x0003
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 5
slave: 0x01
address: 0x0004
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 6
slave: 0x01
address: 0x0005
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 7
slave: 0x01
address: 0x0006
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay channel 8
slave: 0x01
address: 0x0007
write_type: coil
command_on: 0xFF00
command_off: 0x0000
- name: Waveshare relay all channels
slave: 0x01
address: 0x00FF
write_type: coil
command_on: 0xFF00
command_off: 0x0000
The only non-Modbus extra piece is the following automation that reacts to the status change of any of the switches and initiates the update of the Modbus binary sensor (status of all channels).
- id: "<some_unique_id>"
alias: Waveshare relay fetch channel status
mode: queued
max: 10
- id: any_relay_channel_toggled
platform: state
entity_id:
- switch.waveshare_relay_channel_1
- switch.waveshare_relay_channel_2
- switch.waveshare_relay_channel_3
- switch.waveshare_relay_channel_4
- switch.waveshare_relay_channel_5
- switch.waveshare_relay_channel_6
- switch.waveshare_relay_channel_7
- switch.waveshare_relay_channel_8
- switch.waveshare_relay_all_channels
not_to:
- "unknown"
- "unavailable"
- alias: Get current status of all relay channels
service: homeassistant.update_entity
entity_id: binary_sensor.waveshare_relay_status
Statuses of the switches and statuses of individual relay channels are separate entities that should be visualized together. An example Lovelace card:
square: false
type: grid
cards:
- type: tile
entity: binary_sensor.waveshare_relay_status
show_entity_picture: false
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_1
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_2
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_3
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_4
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_5
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_6
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- type: tile
entity: binary_sensor.waveshare_relay_status_7
vertical: true
tap_action:
action: none
icon_tap_action:
action: none
state_content:
- state
- last-changed
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_1
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_2
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_3
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_4
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_5
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_6
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_7
show_state: true
icon_height: 40px
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.waveshare_relay_channel_8
show_state: true
icon_height: 40px
title: MyTest
columns: 8
