I have problem that I know how to read value from modbus, but I do not know how to make it so that I would have entity on which I can see at the same time status (read value) + that I push write value in case of my interaction with entity.
Currently as only read entity:
The goal is to have entity as this one:
This is my current flow:
Flow export:
[{"id":"aefd1c89.6d311","type":"function","z":"a3a75d9a.1537a","name":"Modbus register DOV","func":"msg.payload = { value: msg.payload,\n 'fc': 3,\n 'unitid': 128,\n 'address': 21,\n 'quantity': 1\n }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":2200,"wires":[["48343af1.348654"]]},{"id":"48343af1.348654","type":"modbus-flex-getter","z":"a3a75d9a.1537a","name":"Modbus branje DOV","showStatusActivities":true,"showErrors":true,"logIOActivities":false,"server":"4614aa98.b0a5c4","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":580,"y":2200,"wires":[["55bfeb05.3058f4"],[]]},{"id":"55bfeb05.3058f4","type":"function","z":"a3a75d9a.1537a","name":"msgDOV","func":"var msgDOV = parseFloat(msg.payload[0]);\n\nvar msgDOVo;\n\nmsgDOVo = {payload:msgDOV};\n\nreturn [ msgDOVo ];","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":2180,"wires":[["751afbe6.cf32d4"]]},{"id":"751afbe6.cf32d4","type":"ha-entity","z":"a3a75d9a.1537a","name":"seltron-DOV","server":"9e9d7e1d.b9b0d","version":1,"debugenabled":false,"outputs":1,"entityType":"binary_sensor","config":[{"property":"name","value":"Centralna DOV"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":990,"y":2200,"wires":[[]]},{"id":"a6fc8a86.e1e8b8","type":"inject","z":"a3a75d9a.1537a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":2200,"wires":[["aefd1c89.6d311"]]},{"id":"4614aa98.b0a5c4","type":"modbus-client","name":"SeltronWXD","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.3.142","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"128","commandDelay":"500","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true},{"id":"9e9d7e1d.b9b0d","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
So, can somebody help me?
Thank you.
