Dear all,
I would like to ask your help in order to find a solution for the following:
I need to read humidity value via Modbus from my Uponor heating controller.
According to the documentation is it: Unsigned 16 bit integer
I use the following code to reading multiple registers:
# Uponor 1
# reading all re```gisters for humidity
- name: heating_u1_ch1_12_hum
slave: 1
address: 13
input_type: input
count: 12
precision: 0
data_type: custom
structure: ">12H"
state_class: measurement
scan_interval: 20
than I use the following to get the data:
for 1st value : {{states('sensor.heating_u1_ch1_12_hum').split(',')[0]}}
for 2nd value: {{states('sensor.heating_u1_ch1_12_hum').split(',')[1]}}
the problem that I get values 38435 and 46882 correspondingly insted or real XXs.
What is the right way to convert the data that I read to “unsigned int 16”?
Thank you.
