I am looking to control a Solis inverter via MODBUS without using Home Assistant.
So far I have correctly got the ESP device reading the MODBUS registers and output-ing them to MQTT.
I have spent a few days reading and trying to comprehend the documents, but I struggle with the Lambda stuff, I have very little experience with C++.
I tried to modify the example from here https://esphome.io/components/modbus_controller (about 2/3rds of the way down - the example about resetting the time)
on_boot:
## configure controller settings at setup
## make sure priority is lower than setup_priority of modbus_controller
priority: -100
then:
- lambda: |-
int mode = 33;
esphome::modbus_controller::ModbusController *controller = id(solis);
// create the payload
std::vector<uint16_t> rtc_data = {uint16_t(mode)};
// Create a ModBUS command item with the time information as the payload
esphome::modbus_controller::ModbusCommandItem set_rtc_command =
esphome::modbus_controller::ModbusCommandItem::create_write_multiple_command(controller, 43110, 1, rtc_data);
// Submit the command to the send queue
solis->queue_command(set_rtc_command);
ESP_LOGI("ModbusLambda", "EPSOLAR RTC set to 33");
However I am struggling with what I am doing.
I used to control the MODBUS via Tasmota and Node Red, and this is what got published to MQTT
msg.payload = { //Inverter charging times
"deviceaddress": 1,
"functionCode": 16,
"startAddress": 43143,
"type": "uint16",
"count": 8,
"values": data
node.send(msg);
msg.payload = { //Inverter charging status
"deviceaddress": 1,
"functionCode": 6,
"startAddress": 43110,
"type": "uint16",
"count": 1,
"values": [35]
node.send(msg);
Where ‘data’ is an array of 8 values. I want to write to write to these registers, plus the ones to set the inverter time.
I have moved across to ESPHome but this is the final bit of my setup that I need to convert.
Any help/pointers would be appreciated
