Modbus RS485 configuration - sensors not created
I am trying to connect a MODBUS meter via RS485.
I added the following integration in my configuration.yaml:
modbus:
  type: serial
  method: rtu
  port: /dev/ttyUSB0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
and tried to replace the port line with:
port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
To define the sensors I added the following lines to configuration.yaml:
  platform: modbus
  registers:
    - name: car_energy
      hub: hub1
      unit_of_measurement: kWh
      slave: 1
      register: 0100
      register_type: holding
      count: 2
      data_type: float
    - name: car_power
      hub: hub1
      unit_of_measurement: A
      slave: 1
      register: 001C
      count: 2
      data_type: float
However nothing seems to happen even after I restarted the Home Assistant and the Host. I do not see any error messages in my log files nor are the sensors being created. At least I could nog find an entry using the developer tools. Any suggestion what I could be doing wrong or what I could do to get it working?
I tried to disable my SEMS portal integration and my Smart Meter integration as well to see if there is any interference with that.
Earlier I had a similar kind of experience with integration of buienradar. Could it be that my Home Assistant setup is somehow broken and if so how can I find out what is blocking my configuration?
