Modbus RS485 - Need assistance to setup thermostat BecaSmart BHT-1000 Modbus
Hi all,
I’m pretty new to HA and have one challenge where your support would help me a lot. I need to integrate thermostats BecaSmart BHT-1000 via modbus.
My current status:
  1. I connected the Thermostat via a USB-Adapter. // Status: I can’t see the USB device under discovery. Should I?
  2. configruation.yaml
    I added what I found regarding modbus serial adapters in the //Modbus intergration .
Details:
#Modbus for Thermostats
modbus:
    - name: "Thermostat1"
      close_comm_on_error: true
      delay: 5
      timeout: 5
      type: serial
      baudrate: 9600
      bytesize: 8
      method: rtu
      parity: E
      port: /dev/ttyUSB0
      stopbits: 1
  1. Dashboard: Does not show anything yet.
  2. I know that I now need to configure read/write but I’m unfortunately lost how to configure this.
I would really appreciate if someone could support me with this setup!
Thanks,
Leiste
Modbus Details of the Thermostat
Hello.
Looking at these instructions, my thermostats are very similar. These is my yaml. It’s working fine.
# Example yaml: full udp connection
  - name: modbus_hub
    type: serial
    port: /dev/ttyUSB0
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    stopbits: 1
    delay: 0
    message_wait_milliseconds: 30
    timeout: 5
    # Example configuration.yaml entry
    sensors:
      - name: "Temp Princ"
        unique_id: tem_prin
        unit_of_measurement: °C
        slave: 2
        address: 1
        scan_interval: 10
        input_type: holding
        device_class: temperature
        scale: 0.1
        offset: 0
        precision: 1
        data_type: uint16
