Modbus RTU 1/2/4/8 Channel Relay Output Board
I have problems with configurantion modbus RTU reley like this:
I have tried with code
`modbus:
  • type: serial
    method: rtu
    port: /dev/ttySC0
    baudrate: 9600
    stopbits: 1
    bytesize: 8
    parity: N
    timeout: 1
    switch:
    platform: modbus
    coils:
    • name: Switch1
      hub: hub1
      slave: 1
      coil: 1
registers:
- name: Register1
hub: hub1
slave: 1
register: 1
command_on: 1
command_off: 0
I can use the relay wit this code: echo -en ‘\x01\x05\x00\x00\xFF\x00\x8C\x3A’ > /dev/ttySC0 (open)
echo -en ‘\x01\x05\x00\x00\x00\x00\xCD\xCa’ > /dev/ttySC0 (close)
The adress is 01 and 0xFF00 represents opening the relay, and 0x0000 represents closing the relay
It can also:
Read relay status
Send: FF 01 00 00 00 08 28 12
Returns: FF 01 01 01 A1 A0
Remarks: Bit 0–Bit 7 of the 4th byte of the returned frame, 0x01, represent relay 1–relay 8, 0 is off, 1 is on
Read optocoupler input status
Send: FF 02 00 00 00 08 6C 12
Returns: FF 02 01 01 51 A0
Remarks: IN1–IN8 of the 4th byte of the returned frame, 0x01, represents the input signal of optocoupler 1–optocoupler 8, 0 represents low level, 1 represents high level
Please halp me. I have serched whole forum but cant find the solution with using the relay and the digital inputs.
Just started poking the board. Did you have any success integrating it with HA?
@stivi or @visstro Was you successful? I have similar problem.
I solved the problem in node red, here you have the code.
[{“id”:“5aee700cef3dcb9b”,“type”:“tab”,“label”:“Flow 3”,“disabled”:false,“info”:"",“env”:[]},{“id”:“50a21f04cf34a1a4”,“type”:“server-state-changed”,“z”:“5aee700cef3dcb9b”,“name”:"",“server”:“42e85e30.84e02”,“version”:4,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:""},{“property”:“icon”,“value”:""}],“entityidfilter”:“input_boolean.wlacz_ciepla_wode”,“entityidfiltertype”:“exact”,“outputinitially”:true,“state_type”:“str”,“haltifstate”:"",“halt_if_type”:“str”,“halt_if_compare”:“is”,“outputs”:1,“output_only_on_state_change”:true,“for”:“0”,“forType”:“num”,“forUnits”:“minutes”,“ignorePrevStateNull”:false,“ignorePrevStateUnknown”:false,“ignorePrevStateUnavailable”:false,“ignoreCurrentStateUnknown”:false,“ignoreCurrentStateUnavailable”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:"",“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:"",“valueType”:“eventData”},{“property”:“topic”,“propertyType”:“msg”,“value”:"",“valueType”:“triggerId”}],“x”:350,“y”:360,“wires”:[[“3ca9af3210559dd3”,“8e429d1e69f83ca4”]]},{“id”:“8e429d1e69f83ca4”,“type”:“function”,“z”:“5aee700cef3dcb9b”,“name”:“on”,“func”:“if (msg.payload==‘on’)\n{\n msg.payload=\n {\n ‘value’: true,\n ‘fc’: 5,\n ‘unitid’: 1,\n ‘address’: 0x0000,\n ‘quantity’: 1,\n };\n}\nreturn msg;”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:630,“y”:280,“wires”:[[“ed4a25cb91728459”]]},{“id”:“3ca9af3210559dd3”,“type”:“function”,“z”:“5aee700cef3dcb9b”,“name”:“off”,“func”:“if (msg.payload==‘off’)\n{\n msg.payload=\n {\n ‘value’: false,\n ‘fc’: 5,\n ‘unitid’: 1,\n ‘address’: 0x0000,\n ‘quantity’: 1,\n };\n}\nreturn msg;\n”,“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“libs”:[],“x”:630,“y”:460,“wires”:[[“ed4a25cb91728459”]]},{“id”:“8e0e05c643ef7f5d”,“type”:“modbus-response”,“z”:“5aee700cef3dcb9b”,“name”:"",“registerShowMax”:20,“x”:1030,“y”:380,“wires”:[]},{“id”:“676cd91d8fdb068e”,“type”:“modbus-response”,“z”:“5aee700cef3dcb9b”,“name”:"",“registerShowMax”:20,“x”:1030,“y”:280,“wires”:[]},{“id”:“ed4a25cb91728459”,“type”:“modbus-flex-write”,“z”:“5aee700cef3dcb9b”,“name”:"",“showStatusActivities”:false,“showErrors”:false,“server”:“f0f4cd4889af5c5d”,“emptyMsgOnFail”:true,“keepMsgProperties”:false,“x”:790,“y”:320,“wires”:[[“676cd91d8fdb068e”],[“8e0e05c643ef7f5d”]],“outputLabels”:["",“msg”]},{“id”:“ef2df3fd69c60e2e”,“type”:“inject”,“z”:“5aee700cef3dcb9b”,“name”:"",“props”:[{“p”:“payload”},{“p”:“topic”,“vt”:“str”}],“repeat”:"",“crontab”:"",“once”:false,“onceDelay”:0.1,“topic”:"",“payload”:“on”,“payloadType”:“str”,“x”:450,“y”:280,“wires”:[[“8e429d1e69f83ca4”]]},{“id”:“2829dfb777946395”,“type”:“inject”,“z”:“5aee700cef3dcb9b”,“name”:"",“props”:[{“p”:“payload”},{“p”:“topic”,“vt”:“str”}],“repeat”:"",“crontab”:"",“once”:false,“onceDelay”:0.1,“topic”:"",“payload”:“off”,“payloadType”:“str”,“x”:450,“y”:460,“wires”:[[“3ca9af3210559dd3”]]},{“id”:“42e85e30.84e02”,“type”:“server”,“name”:“Home Assistant”,“version”:5,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true,“heartbeat”:false,“heartbeatInterval”:30,“areaSelector”:“friendlyName”,“deviceSelector”:“friendlyName”,“entitySelector”:“friendlyName”,“statusSeparator”:“at: “,“statusYear”:“hidden”,“statusMonth”:“short”,“statusDay”:“numeric”,“statusHourCycle”:“h23”,“statusTimeFormat”:“h:m”,“enableGlobalContextStore”:true},{“id”:“f0f4cd4889af5c5d”,“type”:“modbus-client”,“name”:””,“clienttype”:“simpleser”,“bufferCommands”:true,“stateLogEnabled”:false,“queueLogEnabled”:false,“tcpHost”:“127.0.0.1”,“tcpPort”:“502”,“tcpType”:“DEFAULT”,“serialPort”:"/dev/ttyUSB0",“serialType”:“RTU-BUFFERD”,“serialBaudrate”:“9600”,“serialDatabits”:“8”,“serialStopbits”:“1”,“serialParity”:“none”,“serialConnectionDelay”:“100”,“serialAsciiResponseStartDelimiter”:“0x3A”,“unit_id”:“1”,“commandDelay”:“10”,“clientTimeout”:“100”,“reconnectOnTimeout”:false,“reconnectTimeout”:"",“parallelUnitIdsAllowed”:true}]
I’m using this relais module LINK, which is connected by this USB-RS485 Adapter.
This module can be easily controlled by these entries in configuration.yaml
modbus:
  - name: ModBusRelaisBoard
    message_wait_milliseconds: 250
    delay: 1
    retries: 3
    retry_on_empty: true
    close_comm_on_error: false
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    parity: N
    port: /dev/ttyUSB0
    stopbits: 1
    switches:
    - name: SW001
      slave: 1
      address: 0
      write_type: coil
    - name: SW002
      slave: 1
      address: 1
      write_type: coil
    - name: SW003
      slave: 1
      address: 2
      write_type: coil
    - name: SW004
      slave: 1
      address: 3
      write_type: coil
    - name: SW005
      slave: 1
      address: 4
      write_type: coil
    - name: SW006
      slave: 1
      address: 5
      write_type: coil
    - name: SW007
      slave: 1
      address: 6
      write_type: coil
    - name: SW008
      slave: 1
      address: 7
      write_type: coil
Sorry, I did not see the notification.
I got it working, but have no notes from that. It was very tedious to work with. I returned it after a week and got an ESP32 board. ESPHome works much better.
I succeeded, took no longer than 15 minutes. yaml posted by luftdieb worked from the start. Thank him for that.
I managed to get relays working thanks to code by luftdieb, but how can i read inputs?
Just started with HA…
Answering to my own guestion, if someone else needs that info.
Its all under modbus integration page, but somehow didnt spot it easily.
For relay status and input status, use slave_count: to read 1-8, inputs can be read with input_type: discrete_input like so:
    binary_sensors:
    - name: Waveshare rele status
      unique_id: waveshare_rele_status
      scan_interval: 3
      slave: 1
      slave_count: 7
      address: 0
      input_type: coil
    - name: Waveshare input status
      unique_id: waveshare_input_status
      scan_interval: 3
      slave: 1
      slave_count: 7
      address: 0
I use https://www.waveshare.com/wiki/Modbus_RTU_Relay_(D)
Hello!
I have the problem that I can’t get anything to work with this device:
I use this screen to communicate with it:
But I can’t manage to turn on any relay.
I’ve read the wikis several times, but I don’t understand what I’m doing wrong.
uart:
  - id: uartmodbus
    tx_pin: 16 # Se comunica invirtiendo Tx con Rx. Esquema eléctrico mal.
    rx_pin: 15
    baud_rate: 9600
    parity: NONE     # Sin paridad
    stop_bits: 1     # Un bit de parada
    data_bits: 8     # 8 bits de datos
modbus:
  - id: modbus1
    uart_id: uartmodbus
# Modbus Controller
modbus_controller:
  - id: relay_controller
    modbus_id: modbus1
    address: 0x1  # Dirección del dispositivo (ajústala según tu configuración)
    update_interval: 5s
switch:
  - platform: gpio
    pin:
      ch422g: ch422g_hub
      number: 2
      mode:
        output: true
      inverted: False
    restore_mode: ALWAYS_ON
  - platform: modbus_controller
    modbus_controller_id: relay_controller
    register_type: holding
    address: 0x0000
Is this in fact working for you ? I am still not able to make the digital input work
