i bought a modbus rtu I / O relay.
Modbus Relay
I connect the relay via a USB converter. There is no problem with output control. I can’t read the status of the inputs. I want to use these inputs in automation. How to read the status. I tried a binary sensor with slave 2 and address 0-255 - so it responded to a change in the state of relay 1. Thank you for the advice on how to read the status of individual inputs.
modbus:
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
switch:
- platform: modbus
scan_interval: 40
coils:
- name: Relay33
hub: sbernice
slave: 2
coil: 0
- name: Relay34
hub: sbernice
slave: 2
coil: 1
- name: Relay35
hub: sbernice
slave: 2
coil: 2
- name: Relay36
hub: sbernice
slave: 2
coil: 3
- name: Relay37
hub: sbernice
slave: 2
coil: 4
- name: Relay38
hub: sbernice
slave: 2
coil: 5
- name: Relay39
hub: sbernice
slave: 2
coil: 6
- name: Relay40
hub: sbernice
slave: 2
coil: 7
