TomP
1
Good morning,
I am trying to communicate with a Schneider PM3250 energy meter via Modbus RTU.
I have successfully edited my configuration.yaml usind the modbus platform and i can read all the register values from PM3250.
However, i can only read the Unsigned INT16 register values, using the ‘register’ field of the configuration.yaml code.
How can i read the “real” values, i.e float or strings values, similar to read_float(), or read_string() functions of minimalmodbus python library ?.
Thank you in advance.
djcovag
(Guillermo)
2
Hi. It happens the same to me.
I have integrated a PM3255 with ComX210 via TCP / IP modbus.
The result is not real.
Anyone who can help us?
Thank.
- platform: modbus
scan_interval: 2
registers:
- name: Sensor1
hub: hub1
slave: 1
register: 3028
#register_type: input #input #holding (default)
unit_of_measurement: V
data_type: float #int (default), uint, float, custom, uint
precision: 2
- name: Sensor2
hub: hub1
slave: 1
register: 3110
unit_of_measurement: Hz
data_type: float
#structure: ">f" #para data_type: custom
precision: 2
#modbus
modbus:
type: tcp #rtuovertcp #tcp
host: 192.168.1.38
port: 502
djcovag
(Guillermo)
3
finally I got it!!
You just have to subtract a number in the entry provided by the Schneider manual table, and add the line “count: 2” (32 bits - size 2).
- platform: modbus
scan_interval: 10
registers:
- name: tension
hub: comx210
slave: 1
register: 3027 #3028 este es el registro del manual (hay que restar uno y que lea dos (count: 2))
count: 2
#reverse_order: false #false
#scale: 1
precision: 1
- name: frecuencia
hub: comx210
slave: 1
register: 3109 #3010 este es el registro del manual (hay que restar uno y que lea dos (count: 2))
count: 2
#reverse_order: true
#scale: 1
precision: 1
data_type: float
# modbus
modbus:
host: 192.168.1.38
port: 502
vith
(vith)
4
- name: "modbusmodbus0"
device_address: 2
address: 0
unit_of_measurement: volt
data_type: float32 # int32
input_type: input
unique_id: "modbusmodbus0"
state_class: measurement
wil give you the 2registers converted to 1decimal value
