Hi
I use a modbus Thermometer and I recently realized that there are no more digits behind the comma. After a short investigation I found out that the problem appeared after the following update: 2024.2 (Which contains the following: Allow modbus “scale” to be negative. #109965)
Here is my config for the Sensor:
- name: Aussen Temperatur
unique_id: modbus_temp_Aussen
slave: 21
address: 0
scan_interval: 600
unit_of_measurement: °C
state_class: measurement
scale: 0.1
offset: -40
Example: Temperatur is 11.7°C
Input from modbus register: 517
517 / 10 - 40 = 11.7
But the output is always rounded. In this cat it says 12.0°C
Do I have to change the configuration or what’s the problem. I didn’t change the config. I only made the update. Thanks for any hint!
