Hello all, I’m abit new to HA and programming.
Just a have a modbus question: I’m currectly using a DDS519MR connected the below.
It’s working correctly but my HA config is wrong:
Thanks in advance.
Thanks in advance.
slave: 1
input_type: input
Thanks for the fast replay, I changed it still no luck.
The funny thing is if I scan it with the modbus tool I get this:
I must be missing something…
zero is broadcast device address
Thanks nikito7 do you mean the “address” should be 0? because I still don’t get back information.
sensors:
- name: 2Solarpanels_current_meter
slave: 1
address: 0
scan_interval: 10
input_type: input
count: 2
precision: 1
data_type: float32
unit_of_measurement: A
device_class: current
state_class: measurement
- name: 2Solarpanels_voltage_meter
slave: 1
address: 4
scan_interval: 10
input_type: input
count: 2
precision: 1 # decimal after the point
data_type: float32
unit_of_measurement: V
device_class: voltage
Use modbus tool with device 1
