Hi. I am trying to connect Uponor floor heating controller with hass using modbus. For some configuration actions I need to update a coil in the following day:
to reset special mode = I have to send 0x0000
to set special mode = I have to send 0xFF00
My first idea was just to use native modbus intergration
switches:
- platform: modbus
scan_interval: 30
coils:- name: heating_floor_state
hub: hub2
slave: 20
coil: 2
So, switch.heating_floor_state will read and write value according to the native modbus functionality.
But in case of I set (via UI) switch to ON or make it OFF that it will take values ‘on’ or ‘off’.
In modbus functionality hass will write coil due the switch status change, I assume, that it will write ‘1’ or ‘0’ there, right?
Because I need to write ‘0xFF00’ and ‘0x0000’ accordingly is there a way how to do it without extra objects?
Or may be it’s just easy: native hass modbus functionality writes 0xff00 when I make correspodning switch (specified as modbus) to ON?
