I’m looking at upgrading my HA from mid 2021, but there are so many breaking changes since then! I need to prepare a fix or something for everything before the upgrade.
I’m getting the following deprecation message about my Modbus sensors… Can anyone show me what the new config should be? I tried to restructure the YAML as per the documentation but couldn’t get it working (Modbus - Home Assistant).
Logger: homeassistant.components.modbus.sensor
Source: components/modbus/sensor.py:111
Integration: Modbus (documentation, issues)
First occurred: July 24, 2023 at 9:53:48 AM (2 occurrences)
Last logged: July 24, 2023 at 9:53:48 AMSensor configuration is deprecated, will be removed in a future release
Here’s a sample of my current config:
modbus:
- name: SI6
type: tcp
host: 192.168.1.2
port: 502
- name: SB5
type: tcp
host: 192.168.1.3
port: 502
# Sensors
- platform: modbus
scan_interval: 3
registers:
- name: SMA Solar Total
hub: SB5
unit_of_measurement: MWh # see register description in section 5.4.1 of document
slave: 3 # use the UnitID you found in Sunny Explorer
register: 30531 # use a register from section 5.4.1 of the document
register_type: input # all registers starting with 3 need to have the type input
count: 2
data_type: int
scale: 0.001
precision: 3
- name: SMA Solar Day Total
hub: SB5
unit_of_measurement: kWh # see register description in section 5.4.1 of document
register: 30517 # use a register from section 5.4.1 of the document
# register_type: input # all registers starting with 3 need to have the type input
count: 4
data_type: int
scale: 0.001
precision: 3
- platform: modbus
scan_interval: 3
registers:
- name: SMA Generator Warmuptime
hub: SI6
slave: 3
register: 40571
unit_of_measurement: ''
precision: 0
count: 2
data_type: uint
