Modbus sensor integration not working after update
I have two versions of home assistant on two separate devices.
The one on which I have configured modes sensors and it 2023.12.0 and here is the current sensor configuration:
     - name: Battery Power
       unique_id: battery_power
       address: 30258
       count: 2
       precision: 3
       slave: 247
       unit_of_measurement: kW
       scale: 0.001
       data_type: int32
       device_class: energy
       state_class: total_increasing
As I said, it reads and it is working perfectly on that home assistant
On the new, updated home assistant with version 2023.12.4, I cannot seem to make it work. First of all, when I let the sensor config like this, it breaks all the modbus configuration for other sensors and I get this message to all my sensors “This entity is no longer being provided by the modbus integration. If the entity is no longer in use, delete it in settings.”.
I have tried changing it like this:
        unique_id: battery_power_solinteg
        address: 30258
        #count: 2
        precision: 3
        slave: 247
        unit_of_measurement: W
        #scale: 0.001
        data_type: float32
        state_class: measurement
        input_type: input
With it written like this, at least I see the other sensors and the sensor appears unavailable.
Did anyone encounter issues like this after an update? The configurations and identical for the modbus on both home assistants but the sensor cannot seem to work on the new one.
Thank you for any suggestions and help.
