Modbus register contains an integer of temperature multiplied by 10.
I can simply convert it to “normal” value with template
sensor.
Is it possible to get “normal” value from modbus
sensor itself, without additional template
sensor?
I have tried to use scale
and data_type
parameters, but failed.
My configuration:
modbus:
type: tcp
host: 192.168.1.200
port: 502
- platform: modbus
scan_interval: 1
registers:
- name: _test_asis
hub: Z031
register: 30000
- name: _test_scale
hub: Z031
register: 30000
scale: 0.1
- name: _test_float
hub: Z031
register: 30000
data_type: float
- name: _test_float_and_scale
hub: Z031
register: 30000
data_type: float
scale: 0.1
Results are:
184
18
0
0
Needed: 18.4
