Modbus solar edge battery is not charging anymore
Hi all I am using the modbus solar edge integration. I am sitting the limit production so I don’t export too much as I have a pretty big array.
For some reason the battery has stopped charging now it hits 99% and is now back down to 97 but is not charging I found storage mode was off and set it to PV excess but it keeps changing it back to off saying the options aren’t valid.
I’m not sure what I’ve done but I would greatly appreciate any help or advice
could it be that the number.solaredge_storage_remote_charge_limit was set when i installed the integration to 11400 - but I have two batteries so its 19000+
I changed thie manually but still no luck
alright my apologies its just trickle charging at this high level.
