That in IEEE-754 format supposed to be 0x4370df60. I converted it here IEEE-754 Floating Point Converter to 240.872558594. The sensor value contains only integer part of the number.
No, because I dont use single register requests at all. For this device I have 56 values in a single request. Multiplied by amount of devices and frequency of requests in the RS485 network I would say this type of requests are not for me.
Does single request uses alternative value parser?
Oh, that was “precision: 4”. If affects all values received in request when data type set to custom and struct used to parse the result.
I think documentation should mention this dependency explicitly - in section that describes custom data_type for modbus.
