Hi all,
I’m struggling with reconfiguration of modbus switch from old config, where config was under ‘switch’ into new type, in which switch configs are defined under modbus hub.
I created following config
Config check returns no error, but after restart i got following error
Then I manually added “verfy_state: true” key to every switch. as described in documentation
After that, config check returns this error
Is this bug or my misconfiguration ?
Troon
(Troon)
April 16, 2021, 9:18am
2
Try true instead of True?
Troon
(Troon)
April 16, 2021, 11:10am
4
Could you paste in the full modbus section from configuration.yaml please? Use the code block to format it properly: no screenshots please. See rule 11 .
Sure, here it is
modbus:
# WEATHER STATION MODBUS
- type: tcp
timeout: 15
host: xxx.xxx.xxx.xxx #hidden
port: 502
delay: 3
sensors:
- name: Barometer
device_class: pressure
unit_of_measurement: mbar
scale: 0.1
slave: 1
precision: 1
input_type: holding
address : 3
scan_interval: 15
- name: Zunanja temperatura
unit_of_measurement: °C
device_class: temperature
scale: 0.1
slave: 1
precision: 1
input_type: holding
address : 6
scan_interval: 15
- name: Hitrost vetra
unit_of_measurement: km/h
slave: 1
input_type: holding
address : 7
scan_interval: 4
- name: Smer vetra
slave: 1
input_type: holding
address : 9
scan_interval: 5
- name: Zunanja vlaga
unit_of_measurement: '%'
device_class: humidity
scale: 1
slave: 1
input_type: holding
address : 18
scan_interval: 15
# SIEMENS MODBUS
- type: tcp
timeout: 10
port: 502
delay: 2
sensors:
- name: Stanje_luc_DALI_1_hodnik
scale: 1
slave: 2
input_type: holding
address : 80
scan_interval: 2
- name: Stanje_luc_DALI_2_pri_termostatu
scale: 1
slave: 2
input_type: holding
address : 82
scan_interval: 2
- name: Stanje_luc_DALI_3_pri_TV
scale: 1
slave: 2
input_type: holding
address : 84
scan_interval: 2
- name: Stanje_luc_DALI_4_vhod_v_hiso
scale: 1
slave: 2
input_type: holding
address : 86
scan_interval: 2
- name: Stanje_luc_DALI_6_letni_vrt_3_lucke
scale: 1
slave: 2
input_type: holding
address : 90
scan_interval: 2
- name: Stanje_luc_DALI_7_letni_vrt_2_lucke
scale: 1
slave: 2
input_type: holding
address : 92
scan_interval: 2
- name: Stanje_luc_DALI_8_nadstresek_3_luci
scale: 1
slave: 2
input_type: holding
address : 94
scan_interval: 2
- name: Stanje_luc_DALI_9_nadstresek_2_lucki
scale: 1
slave: 2
input_type: holding
address : 96
scan_interval: 2
- name: Stanje_luc_DALI_10_nadstresek_1_luc
scale: 1
slave: 2
input_type: holding
address : 98
scan_interval: 2
- name: Stanje_luc_DALI_11_pomozni_objekt
scale: 1
slave: 2
input_type: holding
address : 100
scan_interval: 2
- name: Stanje_luc_DALI_Dnevna_soba
scale: 1
slave: 2
input_type: holding
address : 102
scan_interval: 2
- name: Stanje_luc_DALI_letni_vrt
scale: 1
slave: 2
input_type: holding
address : 104
scan_interval: 2
- name: Stanje_luc_DALI_nadstresek
scale: 1
slave: 2
input_type: holding
address : 106
scan_interval: 2
switches:
- name: luci hodnik spodaj
slave: 1
input_type: holding
address : 111
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient spodaj B
slave: 1
input_type: holding
address : 113
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
slave: 1
input_type: holding
address : 111
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
slave: 1
input_type: holding
address : 113
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient spodaj C
slave: 1
input_type: holding
address : 115
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient spodaj D
slave: 1
input_type: holding
address : 117
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient zgoraj A
slave: 1
input_type: holding
address : 119
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient zgoraj C
slave: 1
input_type: holding
address : 121
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient zgoraj D
slave: 1
input_type: holding
address : 123
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient alternativni set nivojev dali garaza in hisa
slave: 1
input_type: holding
address : 125
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: ambient pomozni (garaža) zadaj
slave: 1
input_type: holding
address : 126
command_on: 1
command_off: 0
scan_interval: 2
verify_state: true
- name: Vklop/izklop prezračevanje klet
slave: 1
input_type: holding
address : 156
command_on: 1
command_off: 0
scan_interval: 2
# HEATING PUMP MODBUS
- type: tcp
timeout: 15
port: 502
delay: 3
sensors:
- name: odcitek_bojlerja
scale: 0.1
slave: 1
input_type: input
address : 109 #110
precision: 1
scan_interval: 30
- name: nastavitev_bojlerja
scale: 0.1
slave: 1
input_type: holding
address : 38 #39
scan_interval: 20
switches:
- name: vklop rezima delovanja-hlajenje
slave: 1
input_type: holding
address : 48 #49
command_on: 2
command_off: 1
scan_interval: 2
- name: vklop aktivnega hlajenja
slave: 1
input_type: holding
address : 49 #50
command_on: 1
command_off: 0
scan_interval: 2
climates:
# Heating pump
- name: ogrevanje sanitarne vode
slave: 1
data_type: int
data_count: 1
scale: 0.1
offset: 0
precision: 2
max_temp: 55
min_temp: 40
temp_step: 1
target_temp_register: 38
current_temp_register: 109
current_temp_register_type: input
scan_interval: 5
- name: Ogrevalni krog hiša
slave: 1
data_type: int
data_count: 1
scale: 0.1
offset: 0
precision: 2
max_temp: 30
min_temp: 10
temp_step: 1
target_temp_register: 21
current_temp_register: 54
scan_interval: 5
- name: Ogrevalni krog garaža
slave: 1
data_type: int
data_count: 1
scale: 0.1
offset: 0
precision: 2
max_temp: 30
min_temp: 10
temp_step: 1
target_temp_register: 26
current_temp_register: 55
scan_interval: 5
Thank you for helping me
Troon
(Troon)
April 16, 2021, 12:12pm
6
I can’t see anything obviously wrong with that. verify_state should be optional according to the docs , so I wonder if there’s something else wrong with the integration.
Anyone else care to chip in?
It’s known issue, which will be fixed in 2021.5 according to this issue thread:
opened 01:13PM - 09 Apr 21 UTC
The problem
After upgrade to version 2021.4.1 from 2021.3.4 modbus switch can't initialize anymore.
Also, found that documentation is not correct. For ex.:...
integration: modbus
