Modbus syntax and function changes
Hey,
from version 0.1185 modbus syntax is no longer working
Changing into the new syntax work BUT device status is not being updated… ( home assistance coils status remain as before)
Any idea how to resolve this issue?
new settings:
  type: serial
  method: rtu
  port: /dev/ttyUSB0
  #port: /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_0133D18C-if00-port0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
  timeout: 4
  #retry_on_empty: true
  #retries: 10
  message_wait_milliseconds: 100
  switches:
    - name: SW001
      slave: 3
      address: 0
      write_type: coil
    - name: SW002
      slave: 3
      address: 1
      write_type: coil
    - name: SW003
      slave: 3
      address: 2
      write_type: coil
    - name: SW004
      slave: 3
      address: 3
      write_type: coil
    - name: SW005
      slave: 3
      address: 4
      write_type: coil
    - name: SW006
      slave: 3
      address: 5
      write_type: coil
    - name: SW007
      slave: 3
      address: 6
      write_type: coil
    - name: SW008
      slave: 3
      address: 7
      write_type: coil
old settings:
  type: serial
  method: rtu
  #port: /dev/ttyUSB0
  baudrate: 9600
  stopbits: 1
  bytesize: 8
  parity: N
  timeout: 4
  #delay_before_tx: 100
  #delay_between_queries: 100
  #message_wait_milliseconds: 50
  # Example configuration.yaml entry for a rs485 connection
  - platform: modbus
    coils:
    #====================================Module #1=============================
   # First Floor
      - name: Switch01
        slave: 10
        coil: 0
      - name: Switch02
        slave: 10
        coil: 1
      - name: Switch03
        slave: 10
        coil: 2
      - name: Switch04
        slave: 10
        coil: 3
      - name: Switch05
        slave: 10
        coil: 4
      - name: Switch06
        slave: 10
        coil: 5
      - name: Switch07
        slave: 10
        coil: 6
      - name: Switch08
        slave: 10
        coil: 7
so no one here is using modbus??
is that even possbile?
