Hi there
I’m new to MODBUS-TCP and would therefore like some guidance for a start-stop function (eventually with a scheduler) for my EV charger.
I can communicate with the charger with MODPULL - all working fine however I’m having difficulties with the yaml file. The address for the start-stop charging is 76 (16-bit signed); 1 = Off, 2= On.
I tried your input to the yaml. file however I doesn’t work when I try to execute with a “button card”. It reads the off position however when I try to switch it on it becomes unavailable immediately and returns to off.
Hereby the exe that works with Modpull. I hope you have another suggestion.
If it goes unavailable, there should probably be some error messages in your log.
I have edited my previous post to correct the command_on and command_off values.
I believe address: 75 is correct, because modpoll uses 1 as the first reference while Home Assistant uses 0.
