jouko
January 19, 2021, 1:21pm
1
Modbus TCP works fine with single connection, but fails with several connections. HA version is 2021.1.4. Commenting out either one of modbus connection, other works ok.
Here is my configuration.yaml
modbus:
type: tcp
host: 192.168.10.203
port: 502
type: tcp
host: 192.168.10.202
port: 502
logger:
logs:
homeassistant.components.modbus: debug
pymodbus.client: debug
Example configuration.yaml entry
platform: modbus
registers:
- name: Ulkolämpö
hub: adam6015_1
unit_of_measurement: °C
slave: 1
register: 2
register_type: holding
scale: 0.0030518
offset: -40.0
precision: 1
- name: Kaukolämpö_tulo
hub: adam6015_1
slave: 1
register: 4
scale: 0.0030518
offset: 160.0
precision: 1
- name: Kaukolämpö_paluu
hub: adam6015_1
slave: 1
register: 3
scale: 0.0030518
offset: -40.0
precision: 1
binary_sensor:
platform: modbus
scan_interval: 10
inputs:
hub: adam6051_1
slave: 1
address: 1
hub: adam6051_1
slave: 1
address: 2
input_type: discrete_input
Errors from log file
2021-01-19 15:16:36 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key “name”. Check lines 19 and 24
2021-01-19 15:16:36 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key “type”. Check lines 20 and 25
2021-01-19 15:16:36 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key “host”. Check lines 21 and 26
2021-01-19 15:16:36 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key “port”. Check lines 22 and 27
krakers
(krakers)
January 20, 2021, 10:23am
2
If you would paste your config as formatted code it would be much easier to help you. It seems your config is wrong.
jouko
January 20, 2021, 12:58pm
3
This is is my configuration.yaml copied from HA. YAML Lint gives Valid YAML!
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Text to speech
tts:
platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
base_url: https://xxxxxxxx.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
modbus:
type: tcp
port: 502
type: tcp
port: 502
type: tcp
host: 192.168.10.204
port: 502
logger:
logs:
platform: modbus
registers:
- name: Ulkolämpö
hub: adam6015_1
slave: 1
register: 2
scale: 0.0030518
offset: -40.0
precision: 1
hub: adam6015_1
slave: 1
register: 4
scale: 0.0030518
offset: 160.0
precision: 1
hub: adam6015_1
slave: 1
register: 3
scale: 0.0030518
offset: -40.0
precision: 1
binary_sensor:
platform: modbus
scan_interval: 10
inputs:
hub: adam6051_1
slave: 1
address: 1
hub: adam6051_1
slave: 1
address: 2
verisure:
username: [email protected]
password: xxxxxxx
krakers
(krakers)
January 21, 2021, 3:24pm
4
Paste it as reformatted text. That’s what this option is for. Otherwise it’s piece of worthless text.
jouko
January 21, 2021, 4:14pm
5
Ok, got now, here it is again
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
http:
modbus:
type: tcp
port: 502
type: tcp
port: 502
# name: adam6051_2
# type: tcp
# host: 192.168.10.204
# port: 502
logger:
logs:
platform: modbus
registers:
- name: Ulkolämpö
hub: adam6015_1
slave: 1
register: 2
scale: 0.0030518
offset: -40.0
precision: 1
hub: adam6015_1
slave: 1
register: 4
scale: 0.0030518
offset: 160.0
precision: 1
hub: adam6015_1
slave: 1
register: 3
scale: 0.0030518
offset: -40.0
precision: 1
binary_sensor:
- platform: modbus
scan_interval: 10
inputs:
- name: Sensor1
hub: adam6051_1
slave: 1
address: 1
- name: Sensor2
hub: adam6051_1
slave: 1
address: 2
verisure:
password: xxxxxxx
type or paste code here
krakers
(krakers)
January 21, 2021, 9:00pm
6
Starting from the beginning it should be like this
modbus:
- name: adam6015_1
type: tcp
port: 502
- name: adam6051_1
type: tcp
port: 502
jouko
January 22, 2021, 7:21am
7
Thanks, works ok now. I must be blind, can’t read doc.
Mattie
(Mattias)
March 14, 2023, 9:19am
8
does this still work? I tried configuring multiple hubs and call them through sensor platform but my HA wont boot correctly when I try. Could you paste your config?
