My first topic is to read values from my solar inverter (Fronius Symo).
I´m able to read the modbus register from the inverter, the problem comes when i realize that the scale changes depending on the power output from the inverter.
The scale comes on register 40084 as a value 0, -1 or -2, that gives the scale for register 40083, as value * 10^scale value.
How can I get a variable scale to the sensor “Production” in my configuration file below?
regards
Patrik
Hi Patrik,
I have seen you have integrated your Fronius Symo via Modbus. I have a Symo Hybrid and would like to integrate mine as well. could you maybe share your configuration with me so I could work on it and find out how to integrate mine? I am also wondering if it is possible to set the scan interval to 5 seconds.
Thanks a lot
I am also interested to do this with my Symo Inverter.
It seems it should be possible with no additional hradware/equipment. There is general Modbus integration https://www.home-assistant.io/integrations/modbus/ and on inverter local admin page, I can set Modbus to be available on TCP:
Is this enough ?
How do I know when to find values (registry ?) and how to potentially control inverter (if this is possible).
Last, is this integration better then “normal” one with web links ?
