I’m trying to start my first project with Modbus and I can’t get past step 0…
My intention is to use this type of POE equipment, to read the inverter, the boiler… and integrate it into HA.
If you are using serial, type should be serial and then it’s not baud_rate but baudrate. Same for stopbits. Also, parity, method and bytesize are mandatory as per the error message and the documentation
This is the same, write for ESPHome with modbus_controler. But I need to use only Modbus, my problem is that I can’t find something similar to “number” entity.:
