1100.Bat First Start High eight bit:hour 0-23
Low eight bit: minute 0-59
How would I go about constructing such in thing such that in the UI I have two separate fields, but they get constructed into one thing in modbus to read/write to the controller?
Will need 3 sensors: one for read/write to controller and 2 for the UI.
On the controller sensor, split up value on the on_value, then publish to the 2 UI sensors.
Same for the other way around: when either UI sensor’s value changes, again use “on_value” to compose the joined value and publish it to the controller sensor.
And to construct word from 2 bytes: (uint8_t)hour << 8 | (uint8_t)minute
