I’ve successfully been able to read out a whole bunch of registries from my SAJ solar inverter using the vendor’s Modbus communication protocol (https://www.solartoday.nl/wp-content/uploads/saj-plus-series-inverter-modbus-protocal.pdf)
uart:
tx_pin: ${tx_pin}
rx_pin: ${rx_pin}
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
#debug:
# direction: BOTH
modbus:
uart_id: uart_bus
modbus_controller:
- id: saj
## the modbus device addr
address: 0x1
modbus_id: modbus0
setup_priority: -10
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: saj
address: 0x0107
register_type: holding
value_type: U_WORD
device_class: "voltage"
unit_of_measurement: "V"
state_class: "measurement"
accuracy_decimals: 1
filters:
- multiply: 0.1
However, of all the registeres available for reading, only 2 special registries are meant for writing to.
I’m particularly interested in writing to register “801FH” (at the bottom of the pdf) which would allow me to send a percentage to limit the power output.
Was thinking of using a Number Slider to configure that.
Easy! I thought…
number:
address: 0x801F
mode: slider
use_write_multiple: true
step: 10
min_value: 0
max_value: 100
value_type: U_WORD
device_class: "power"
unit_of_measurement: "%"
Unfortunately, I get an error from that:
[15:08:12][V][modbus_controller:047]: Sending next modbus command to device 1 register 0x801F count 1
[15:08:12][V][modbus:199]: Modbus write: 01.03.80.1F.00.01.9C.0C (8)
[15:08:12][V][modbus_controller:509]: Command sent 3 0x801F 1
[15:08:12][V][modbus:042]: Modbus received Byte 1 (0X1)
[15:08:12][V][modbus:042]: Modbus received Byte 131 (0X83)
[15:08:12][V][modbus:042]: Modbus received Byte 2 (0X2)
[15:08:12][V][modbus:042]: Modbus received Byte 192 (0Xc0)
[15:08:12][V][modbus:042]: Modbus received Byte 241 (0Xf1)
[15:08:12][D][modbus:119]: Modbus error function code: 0x83 exception: 2
[15:08:12][E][modbus_controller:091]: Modbus error function code: 0x3 exception: 2
[15:08:12][E][modbus_controller:100]: Modbus error - last command: function code=0x3 register address = 0x801F registers count=1 payload size=0
It uses 01.03 —> device 1, function 0x03 which is the command to read. According to the vendor’s spec, 10 should be used.
I’m under the impression that I need to do something a bit more complicated than that. Any suggestions?
