Modbus values combined wronge
Hi
I have connected 3 x EM340 modbus energy meters to my RPI4 with a CH340 usbstick.
I have the following code in my configuration.yaml
modbus:
  - name: G12A_mod
    type: serial
    baudrate: 9600
    bytesize: 8
    method: rtu
    retry_on_empty: true
    retries: 20
    close_comm_on_error: true
    message_wait_milliseconds: 40
    parity: N
    port: /dev/ttyUSB0
    stopbits: 1
    sensors:
      - name: test1
        scan_interval: 30
        slave: 1
        address: 1024
      - name: test1_1
        scale: 0.001
        precision: 3
        scan_interval: 30
        slave: 1
        address: 1026
      - name: test2
        scan_interval: 30
        slave: 2
        address: 1024
      - name: test3
        scan_interval: 30
        slave: 3
        address: 1024
      - name: test2_2
        scale: 0.001
        precision: 3
        scan_interval: 30
        slave: 2
        address: 1026
      - name: test3_3
        scale: 0.001
        precision: 3
        scan_interval: 30
        slave: 3
        address: 1026
template:
  - trigger:
      - platform: time_pattern
        seconds: "/30"
  - sensor:
    - name: "meeter2"
      state: "{{ states('sensor.test2') | float   + states('sensor.test2_2') | float  }}"
      unit_of_measurement: "kWh"
  - sensor:
    - name: "meeter1"
      state: "{{ states('sensor.test1') | float   + states('sensor.test1_1') | float  }}"
  - sensor:
    - name: "meeter3"
      state: "{{ states('sensor.test3') | float   + states('sensor.test3_3') | float  }}"
I get usage in two pices, INT part of usage, and decimal part. I combine it sensor meeter2, which contains of test2 and test2_2
Sometime I see some peaks in values:
My guess would be it take the int part and combine it with the wrong decimal part. In the screen dump my guess is it is 2970 + 0.997 and It should have been 2970 + 0.011
Any ideas to resolve so I ensure it is the correct int and decimal part there are combined ( from same batch of reading), I guess it is because decimal part was not received and the the value before are used.
