Hello everyone, I’m new here and can’t get any further.
I have already successfully integrated my WAGO 750-841. Can also write and read.
Now in my PLC program I write Bool Register 8192… to control my lamps. The registers 512… are for the digital output. Since I have the lamps running as buttons, I would have to set the set value from 1 to 0. So with every action 1 and 0. So the whole thing runs as a toggle button. Can someone tell me how I should do this when switching, so the regsiter 8192 is only described with 1 then with 0. Do I have to do this with a script? I am despairing.
- unique_id: PCF_in_8213
slave: 1
address: 8213
scan_interval: 1
command_on: 1
command_off: 0
write_type: coil
verify:
input_type: coil
address: 533
- unique_id: PCF_in_8203
slave: 1
address: 8203
scan_interval: 1
command_on: 1
command_off: 0
write_type: coil
verify:
input_type: coil
address: 523
Many Thanks
