I have two identical ND meters. When I Read holding register 515. One of them reads correctly, but the other gives me an odd negative value.
I’ve checked the direct reading from the ND device, and this shows correctly, but not in HA. Any ideas why. The Register 515 on device 40007 works fine, 40008 gives weird value.
Any Hints?
modbus:
- name: "40007"
type: tcp
host: 172.16.32.7
port: 502
sensors:
- name: 40007_Power_All_Total
slave: 1
address: 2816
input_type: holding
unit_of_measurement: kWh
device_class: power
state_class: measurement
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40007_Power_P1_Total
slave: 1
address: 2823
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40007_Power_P2_Total
slave: 1
address: 2826
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40007_Power_P3_Total
slave: 1
address: 2829
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40007_515_Total_kWh
slave: 1
address: 515
input_type: holding
device_class: energy
state_class: total_increasing
scan_interval: 3
- name: 40007_514_Total_kWh
slave: 1
address: 514
input_type: holding
scan_interval: 3
- name: 40007_Export_Total_kWh
slave: 1
address: 525
input_type: holding
scan_interval: 3
- name: "40008"
type: tcp
host: 172.16.32.8
port: 502
sensors:
- name: 40008_Power_All_Total
slave: 1
address: 2816
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40008_Power_P1_Total
slave: 1
address: 2823
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40008_Power_P2_Total
slave: 1
address: 2826
input_type: holding
device_class: power
count: 1
scale: 0.1
offset: 0
scan_interval: 3
- name: 40008_515_Total_kWh_TEST
slave: 1
address: 515
input_type: holding
scan_interval: 3
- name: 40008_514_Total_kWh
slave: 1
address: 514
input_type: holding
scan_interval: 3
- name: 40008_Export_Total_kWh
slave: 1
address: 525
input_type: holding
scan_interval: 3
