Modbustcp problem, only -4-5 sensors appear in mqtt
hello can someone help, why are the sensors not showing up, it seems like there is some autodiscover problem
sometimes 3 sometimes 4 sometimes 5 sensors, but need 8-9
modbus tcb via wifi
  - platform: custom
    lambda: |-
      auto mg_l = new ModbusTCPSensor("172.16.48.49", 502, 4, "AB_CD", 150000);
      App.register_component(mg_l);
      return {mg_l};
    sensors:
      - name: "Dissolved_Oxygen_mgL_5711"
        unit_of_measurement: "mg/L"
        state_class: measurement
  - platform: custom
    lambda: |-
      auto co2 = new ModbusTCPSensor("172.16.48.49", 502, 13, "CD_AB", 200000);
      App.register_component(co2);
      return {co2};
    sensors:
      - name: "CO2_oxy_5711"
  - platform: custom
    lambda: |-
      auto redox = new ModbusTCPSensor("172.16.48.49", 502, 33, "CD_AB", 180000);
      App.register_component(redox);
      return {redox};
    sensors:
      - name: "Redox_Potential_5711"
        unit_of_measurement: "mV"
        device_class: voltage
  - platform: custom
    lambda: |-
      auto ph = new ModbusTCPSensor("172.16.48.49", 502, 23, "CD_AB", 150000);
      App.register_component(ph);
      return {ph};
    sensors:
      - name: "pH_5711"
  - platform: custom
    lambda: |-
      auto o3 = new ModbusTCPSensor("172.16.48.49", 502, 43, "CD_AB", 210000);
      App.register_component(o3);
      return {o3};
    sensors:
      - name: "O3_5711"
  - platform: custom
    lambda: |-
      auto temp_o2 = new ModbusTCPSensor("172.16.48.49", 502, 10, "AB_CD", 210000);
      App.register_component(temp_o2);
      return {temp_o2};
    sensors:
      - name: "temp_o22"
        unit_of_measurement: "°C"
        device_class: temperature
#pragma once
#include "esphome.h"
// POSIX/lwIP socketid
#include <sys/socket.h>
#include <netdb.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <unistd.h>
#include <cstring>
#include <string>
class ModbusTCPSensor : public esphome::PollingComponent, public esphome::sensor::Sensor {
 public:
  ModbusTCPSensor(const std::string &host,
                  uint16_t port,
                  uint16_t register_address,
                  uint8_t unit_id,
                  const std::string &byte_order,
                  uint32_t update_interval_ms)
      : esphome::PollingComponent(update_interval_ms),
        host_(host),
        port_(port),
        register_address_(register_address),
        unit_id_(unit_id),
        byte_order_(byte_order) {}
                  uint16_t port,
      : ModbusTCPSensor(host, port, register_address, 1, byte_order, update_interval_ms) {}
  void setup() override {
    ESP_LOGCONFIG(TAG, "ModbusTCP init host=%s port=%u reg=0x%04X",
                  host_.c_str(), port_, register_address_);
    this->set_accuracy_decimals(2);
  void update() override {
    int fd = -1;
    if (!open_and_connect_(fd)) {
      ESP_LOGE(TAG, "TCP connect failed");
      return;
    uint8_t req[12];
    build_request_(req);
    if (!write_n_(fd, req, sizeof(req))) {
      ESP_LOGE(TAG, "Write failed");
      ::close(fd);
      return;
    uint8_t hdr[9];
    if (!read_n_(fd, hdr, sizeof(hdr))) {
      ESP_LOGE(TAG, "Header read failed");
      ::close(fd);
      return;
    uint8_t fc = hdr[7];
    uint8_t bc = hdr[8];
    if (fc & 0x80) {
      ESP_LOGE(TAG, "Modbus exception FC=0x%02X", fc);
      ::close(fd);
      return;
    if (bc < 4) {
      ESP_LOGE(TAG, "Bytecount too small");
      ::close(fd);
      return;
    uint8_t payload[32];
    if (!read_n_(fd, payload, bc)) {
      ESP_LOGE(TAG, "Payload read failed");
      ::close(fd);
      return;
    float value = decode_float_(payload, byte_order_);
    publish_state(value);
    ::close(fd);
 protected:
  static constexpr const char *TAG = "modbus_tcp";
  std::string host_;
  uint16_t port_;
  uint16_t register_address_;
  uint8_t unit_id_;
  std::string byte_order_;
  uint16_t tx_id_ = 1;
  void build_request_(uint8_t *o) {
    uint16_t tid = tx_id_++;
    o[0] = tid >> 8;
    o[1] = tid & 0xFF;
    o[2] = 0x00;
    o[3] = 0x00;
    o[4] = 0x00;
    o[5] = 0x06;
    o[6] = unit_id_;
    o[7] = 0x03;
    o[8] = register_address_ >> 8;
    o[9] = register_address_ & 0xFF;
    o[10] = 0x00;
    o[11] = 0x02;
  float decode_float_(const uint8_t *d, const std::string &o) {
    uint32_t raw;
    if (o == "AB_CD")
      raw = (d[0] << 24) | (d[1] << 16) | (d[2] << 8) | d[3];
    else
      raw = (d[2] << 24) | (d[3] << 16) | (d[0] << 8) | d[1];
    float f;
    std::memcpy(&f, &raw, sizeof(f));
    return f;
  bool open_and_connect_(int &fd) {
    fd = -1;
    struct addrinfo hints = {};
    hints.ai_family = AF_INET;
    hints.ai_socktype = SOCK_STREAM;
    struct addrinfo *res = nullptr;
    char port_str[8];
    snprintf(port_str, sizeof(port_str), "%u", port_);
    if (::getaddrinfo(host_.c_str(), port_str, &hints, &res) != 0 || !res)
      return false;
    fd = ::socket(res->ai_family, res->ai_socktype, 0);
    if (fd < 0) {
      ::freeaddrinfo(res);
      return false;
    if (::connect(fd, res->ai_addr, res->ai_addrlen) != 0) {
      ::close(fd);
      fd = -1;
      return false;
    return true;
  bool write_n_(int fd, const uint8_t *b, size_t n) {
    size_t s = 0;
    while (s < n) {
      ssize_t x = ::send(fd, b + s, n - s, 0);
      if (x <= 0) return false;
      s += x;
    return true;
  bool read_n_(int fd, uint8_t *b, size_t n) {
    size_t r = 0;
    while (r < n) {
      ssize_t x = ::recv(fd, b + r, n - r, 0);
      r += x;
    return true;
Is it possible that MQTT auto discovery is changed?
the same problem is with many sensors that MQTT sensors do not appear
